Does the Q8 battery tube also fit with this final production model? I saw Sofirn mention bringing the Q8 extension tube to life on Facebook is why I ask.
Wow, great pricing on the with batteries option! (depending on the batteries included, which I will have to have you guys interpret how good they are for me )
DBSAR, quick question for you (or the group). Has anyone tried out the new RAVPower Solar Charger (Amazon.com)? 21W instead of the 10W ECEEN and only ~$13-15 more, depending when it goes on sale. I wanted to get something a little more powerful to charge a larger battery pack and wondering if this would also work well for the LT1.
Which solar power bank was the one in the video? I see a few different sizes for that manufacturer - X-Dragon.
Is it better to get a solar charger like the one mentioned earlier in this thread and a separate power bank or an integrated solution like the X-Dragon one in the video?
I’m new here so I apologize if posting this question in this thread is frowned upon. However, I will be buying this to support my BLF LT1s and I’m sure others are curious about this as well.
In general, I think it is better to have a solar panel and a battery separate (unless you need it to be as compact as possible). My thinking here is that if one or the other dies, you can replace that part instead of the whole thing. Also, you could use one panel with different batteries depending on your needs (bigger batteries for longer trips, etc) or just the solar panel by itself to save weight.
Based on the work DBSAR has done around here, I’d say anything he likes is probably a quality product. If it fits your needs and budget, the one in his video is probably a good bet for a combo device. he also recommended a regular solar panel (without battery) earlier in the thread from a company called ECEEN (use the search to find the link) if that is more your speed. This lantern paired with the ECEEN and 4x 3500mah cells is said to be capable of providing light “indefinitely”, so it sounds like a winning combo to me. The X-Dragon with a built in power bank would be useful for charging other devices, extending the run time of this one, or using it without the battery tube installed.
hope that doesn’t “muddy the waters”… the TLDR is that I think in general, splitting the task between two devices (solar panel and battery) is more robust, but anything DBSAR likes is surely a good buy.
