So, i just asked Simon [the official owner of Convoy @ convoy.aliexpress.com] and he answered me with the following images in This thread
So tonight i had to find out whether it was actually a PTC or NTC, to remove the item or make a solder connection between the pads.
To find out i measured the component Simon pointed out at room temperature which gave me around 90K, after warming up the driver with my wife’s blow dryer the resistance dropped to 35K.
So i desoldered the NTC and did a second second test on only the component (which gave different readings ofcourse, since measuring resistance in a loop is actually a no-go)
No load resistance gave me 105K and after heating up with the blow dryer gave me around 35K (it raised quite fast, that’s why the picture shows ~60K)
Now the light gets hot after a few minutes, which means, mission accomplished, now i have an L21A without temperature protection! I LIKE IT !
Good job Yokiamy, i am interested in this mod also but i cannot see the pictures in the Convoy tread. Is it possible to reupload them to imgur, please?
Interesting, understandable, logical. The temperature protection gets activated by the resistance reduction in the NTC. If the NTC is removed the resistance “gets high” and cannot change. The temperature limit is thus removed.
Concerning the ramping driver, I modified a ∅22mm unit for a little bit more current (8.8A theoretical, 8.1+A measured) and two ∅17mm units for less current (5A and 4A, hitting ≈4.75A and 3.8+A when measured). The ∅17mm unit set for 4A had a small problem, with the first seconds of the ramping unseen and the 3rd mode setting clicks also unseen. Couldn't investigate the issue, the flashlight was for a colleague and he came home, got it and went away despite the thing.
The ramping driver has a weird UI which may not be everyone's liking.
Can you explain how you made the ramping driver less current? Would it be possible to run at 3A for an XML2? If you had to swap out chips then I won’t be doing it
By swapping out the sense resistor stack. Comes stock with 5mΩ, this means 40mV theoretical (I = R × V) sense voltage, although seems to be a bit less in practice (?). I added an R050 on top of the stock R005 in the “stock 8A” ∅22mm driver which ended up measuring 8.1+A. Concerning the smaller drivers I installed two stacked R020s in the one I set for “4A”, and for the one I set at “5A” I went with an R010 plus R050 plus R200.
Barkuti, which component is the sense resistor stack? I think I see the R005 on the ramping driver, but do you know which it is on the 6A driver? I assume R010?
So what I’m understanding is that more resistance = higher amperage… Now to work out the right number to hit ~7.5A
Edit: I’ve found a similar driver to the 6A one, but this is apparently 7A: https://www.aliexpress.com/item/33005190273.html - looks like it uses R015, but there’s a few other components of different values, too.
No, by adding the same resistor on top, your total resistance will be half of the value.
(Electronics series parallel basics) This will increase current output, many people did this with the L6 resistor mod (R100 or R120)
If you do that the driver won't be able to regulate at all. This means no ramping and no modes. I haven't tried it, though.
You still need to tweak the sense resistor stack value for it to work. You could try an R004 on top, it could work well or it may not. Add some heatsinking to the thing in such a case, as you'll be above the maximum power rating for single 1206 resistors (a couple stacked one doesn't changes this significantly). A good mound of thermal glue above sense resistor and MOSFET could help.
If the driver uses R010 for 6A this means sense voltage is Vsense = R × I = 10mΩ × 6A = 60mV. If you want to add 1.5A, you need Rextra = V / I = 60mV / 1.5A = 40mΩ or an R040 in parallel with the existing R010.
I have not measured how that driver behaves actually but if you really want to be sure to hit 7.5A, add some more conductance is my advice. I'd look for an R030, which would raise the maximum current to 8A theorerical (6A + 2A), albeit it would leave the actual figure in close proximity to 7.5A effective due to MOSFET heating, imho.
