Probably, this is more or less a matter of (inefficient) thermal conductivity. If the driver gets hot like crazy but the host structure around it remains much cooler Simon should look for ways to improve the thermal transfer and dissipation. I could imagine that the driver does not make good contact to the M3 host or cannot dissipate the heat due to non-conductive materials.
I faced the same situation with my M3. No matter how often I restart the highest mode, it never really gets very warm on the outside.
Have you guys tried stuffing the driver cavity with silicone cubes? I found it worked well with a Convoy S3 and 5A 4-mode Convoy driver. The host did become hotter* before thermal regulation kicked in. In the M3, a lot of the driver’s heat should be absorbed by the silicone cubes allowing for longer turbo runs.
After removing the NTC of the driver, the temperature regulation is gone.
I am very happy with it now, the light now works as intended, just full power on max (and yes, it does get hot after a couple of minutes, but still a lot better then the Astrolux FT03 though)
Since the drive detects the temperature of the component, not the temperature of the surface of the case, I have raised the threshold for temperature protection at around 60 degrees.
In addition, more heat-dissipating rubber blocks can be added to the driving surface.
Sorry I don’t fully understand the picture. The circled spot is I suppose the thermal sensor controller, but what should we do to disable it if we don’t want the temperature control on the SST40 4-mode driver? The circled part has to be unsoldered? Pardon my ignorance…
Yes, I think some only exist in spec sheets. Kind of like “if we were to produce some, this would be the item number for it”.
For endeavors such as this, Octopart is a great resource… just search for the Cree order code. Pretty much anything I’ve found has a 1000pc MOQ though. AVNET supposedly has it in stock (with the 1000pc MOQ). Other places such as Mouser and Digikey also list it, “non-stocked” with 1000pc MOQ meaning that you should be able to place an order (for 1000pcs) and they’d procure it for you.
Now if you don’t mind going for the ANSI versions instead of the EasyWhite versions, you can get the XHP35-HI 4000K 90-CRI in B4 flux bin (XHP35A-H0-0000-0D0UB40E5) from Mouser in 1pc increments for USD $6.50
I was able to get 2 minutes runtime from the M3 on turbo … on a bicycle, while I was in motion.
I had to switch it off, because someone appeared in the road, and I did not want to blind him/her
Actually, id I don’t want to see very much ahead, but just avoid from overhead trees, etc, the High mode is just enough. I even put a lens in front of it to have a wider beam, which of course make the hotspot less bright.
