Wait, so TIR optics have larger spill compared to reflector on s2 ? is it because optics are tiny 10mm or something else ?
because i’ve ordered 20mm optics (10199) to use with this osram led and i want almost 0 spill to decrease glare. did i made a wrong choice ?
Please note that this is a TRIPLE TIR (carclo 10507) not a single led TIR! It has 3 White Flat leds below it so the beam will be wider than the S2 (1 White Flat + Smooth reflector)!
About your choice, I am not sure because I don’t know that optic. Also, once it is a TIR (Total Internal Reflection) I am not sure if you will be able to get 0 spill on it! But please report when you have it!
Also, please note that the Acebeam has a very that hotspot but then it has “rings” around it! So the spill is still there but it is not so much delineated.
See them here:
Convoy S2 (Left) vs Acebeam TK16 (Right)
Yes, that’s what i thought after posting that as well, since it’s 3x10mm optics beam will be wider than single 20mm optic such as carclo 10199.
since you own both lights, maybe you can answer this - s2 vs tk16, which one has more glare if it’s switched on towards year direction but not pointed at your eyes straight ? i believe s2 should have more glare because reflector.
thing is i’m trying to modify my motorcycle auxiliary spot lights, to reduce glare for incoming traffic. so far i have tried replacing stock xml2s to CSLNM1, it did increase throw and reduced glare tiny bit, but leds got burned within 2-3 hrs because low clearance between reflector and led mcpcb short the wires. so now i’m trying to replace reflector with 20mm tir optics. with CSLNM1. hopefully it will work better.
And maybe a bit of luck. I put a white flat in a C8 and the results were almost perfect. Almost
Though I did make some mistakes along the way and a lot of thing could have been done better.
So I bought a set of identical or better parts, treated those with utmost care, and tried to build a perfect one.
To make a long story short: despite my efforts, whatever I tried, it did not even come close to the first light.
Lights are like dogs, treat them well and with respect, because you might never find another one like the first.
can we reflow CSLNM1.TG on a mcpcb which is designed for black flat ? is there any issues with thermal pad being cathode, since white flat has isolated thermal pad ?
I need to report that i’ve placed CSLPM1.TG 2mm in GT mini using L4P 20mm 3030MCPCB.
I had protected 18650 nearby so i throw it in and ran the sucker. After few reflector adjustments beam was ok.
And now cute part, finally found IMR 18650 and replaced the protected cell but now ramping to HI is much much brighter. And then double click for Turbo showed angry blue!
Was a bit surprised cause some modders are running it hard in GT mini and i have to use protected cell 8/
Didn’t meassure amps on the tail cause of lack of time but i was curious did anyone else also got the same results and at which amps?
I’m not surprised, the PM1 has an extremely low Vf, lower than anything else (see the OP of this thread) so it will pull every bit of current a battery can provide. You depend on resistances in the system (internal battery resitance, springs, ledwires, FET) to keep the current restrained.
Thx djozz. I was too lazy to read all the way up but initial look at the first posts revealed what you just said. Will have to use it with protected only which is not bad since they are picking up dust these days.
I dropped a PM1 in my GT Mini, but if I put a 30Q in it, it turns blue on Turbo.
You have to use a lower drain cell, to limit the current at about 8A.
It’s not ideal, a new regulated driver would be way better but hey it’s cheap
Hes thrown a real spanner in the works because i now cannot decide on using an L2 host or a Jax z1 i was sure the jax was going to be the better choice but now im on the fence again
