Low-cost copper pills, spacers, optics, drop-ins. Custom parts.
1781 posts / 0 new
Skylight
Skylight's picture
Last seen: 3 hours 32 min ago
Only spacers or also threaded parts? If also threaded, a short tube for Convoy C8+, please.
kiriba-ru
kiriba-ru's picture
Last seen: 3 hours 57 min ago
Spacers or threaded parts that I have already made or parts for hosts that I have on hands. Drawings are preferable.
Tube is too complicated part, it needs to have perfect knurling, flatnesses, ano etc.
Skylight
Skylight's picture
I understand, thank you. Are there any interesting or popular hosts you have on hand?
kiriba-ru
kiriba-ru's picture
Dont have any modern hosts except S11 and S21. Before I got Q8, all other hosts are even older.
Chatika vas Paus
Chatika vas Paus's picture
Last seen: 7 min 2 sec ago
And something like that? For 18350 only and quad.
http://budgetlightforum.com/comment/1033063#comment-1033063
kiriba-ru
kiriba-ru's picture
Such things are posssible.
Chatika vas Paus
What is the cost of copper?
kiriba-ru
kiriba-ru's picture
Too many factors, pm details please.
Do you need pill inside or solid shelf. Do you need retaining ring for driver and driver size.
Would not like to make driver retaining threads in Cu. Can press fit brass insert.
Chatika vas Paus
Mail
kiriba-ru
kiriba-ru's picture
kiriba-ru wrote:
Couple of M2 aluminium sets in stock.
Still in stock. Also have two quad sets with copper spacer for S11.
Few words about S2+ single pill. They are available both with convoy or special (do not confuse with “custom”, this are made special for this pills) retaining rings. Ring threads have extended length so both support 2-sided drivers. However, I can not recommend forcing AMCs down with convoy ring (even if it helps with chips cooling, you can easily damage them). Special rings have wide lip with slots, screwing them hard should be more easy and safety than thin “custom” rings. Special ring doesnt allow using driver negative pad without spring, also there might be some issues with very long cells.
mozart.f
Last seen: 12 months 3 days ago
Hi kiriba-ru.
Do you have in stock ledil cute 3ss lens?
kiriba-ru
kiriba-ru's picture
Yes.
flightless22
flightless22's picture
Last seen: 46 min 50 sec ago
I received the S2+ spacers. Put one together, no problems. Thumbs Up
Caleb
Caleb's picture
Last seen: 1 hour 2 min ago
kiriba-ru wrote:
Open for single quantities custom requests until August.
C8TT head for M21A threads
Alu head for 40mm anna optics
Brass retaining ring for 17/20mm driver
Cu spacer
Stainless bezel
AR coated glass
O-ring
Is it possible to taper the outside diameter of the cooling fins down a little towards the battery tube?
I am probably not the only one who would purchase this set.
kiriba-ru
kiriba-ru's picture
If it will be rethreaded for M21A tube, several fins will fall down.
Caleb
Caleb's picture
What about a new design to accommodate the larger tube… not a rethread?
kiriba-ru
kiriba-ru's picture
C8TT was developed as test stand. I wanted such project for myself but decided to make a batch to make it available for others. This project is not profitable, machining time is long so it was more reasonable to make 20 or 30 simple spacers instead.
There is also another problem. Simon get so many requests about new convoys so I guess there will be changes in dimensions. I wouldnt like have batch of parts that dont fit actual batch of hosts.
kiriba-ru
kiriba-ru's picture
Also, have found few rare items:
2019-06-28-15-29-42
Left is for SK-68 and right is for HD-2010.
Chatika vas Paus
I’ll take sk68 with my next order. Can you keep it for me?
kiriba-ru
kiriba-ru's picture
Sure.
Skylight
Skylight's picture
Could you produce some more SK68 copper pills?
kiriba-ru
kiriba-ru's picture
Yes, if you are ready to pay $10/pc.
Skylight
Skylight's picture
I’m not sure if these pills fit a SK68 clone of mine. Could you please tell me the height and the diameter at the top and at the threads?
kiriba-ru
kiriba-ru's picture
Top is 21mm, threads are m19×1.
Skylight
Skylight's picture
Thank you for the sizes, but I have another pill. I will order some other things then. Thumbs Up
korpzgrinda
korpzgrinda's picture
Last seen: 14 hours 53 min ago
Location: Eastern Woodlands in the Wilderness of North America
I was excited to see a small package from Russia in the mail today! A quad spacer for the Convoy S11 is all the rage these days… Big Smile or should be soon. The host and emitters are still in transit from China though. Thanks kiriba!
Skylight
Skylight's picture
Recently I received the items from my first order from kiriba-ru. They arrived in two weeks with full tracking. The packaging is incredibly well done, every single item is in a plastic bag, wrapped with foam, then wrapped again and glued with tape. Thumbs Up Crown
I’d like to share some fotos of the C8TT head with Ledil Anna 7 copper spacer as it is a real beauty and I never expected it to be that nice. Love
kiriba-ru
kiriba-ru's picture
S11 sets sold.
kiriba-ru
kiriba-ru's picture
Last one rejected S2+ triple pill is available.
No plans for big batches anymore, demand is very low, it would take years to sell another batch.
I still have many single pills and triple spacers, if anyone needs triple pill I can solder spacer and single pill together and drill a through hole so they could replace a regular triple pill.
KevinZA1988
KevinZA1988's picture
Last seen: 4 hours 7 min ago
How much for shipping to South Africa?? It will be the deal breaker, if the Paypal fees aren’t already.
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
