【convoy】H4 and B35AM options are updated
That is one good looking headband Simon!
Yes.
Have a look over HERE how i did it
Can someone help with finding this LED? :person_facepalming:
Do some LED bins only exist on paper? Seems that way.
I also tried finding that LED the day he launched it… Nothing!
Yes, I think some only exist in spec sheets. Kind of like “if we were to produce some, this would be the item number for it”.
For endeavors such as this, Octopart is a great resource… just search for the Cree order code. Pretty much anything I’ve found has a 1000pc MOQ though. :frowning: AVNET supposedly has it in stock (with the 1000pc MOQ). Other places such as Mouser and Digikey also list it, “non-stocked” with 1000pc MOQ meaning that you should be able to place an order (for 1000pcs) and they’d procure it for you.
Now if you don’t mind going for the ANSI versions instead of the EasyWhite versions, you can get the XHP35-HI 4000K 90-CRI in B4 flux bin (XHP35A-H0-0000-0D0UB40E5) from Mouser in 1pc increments for USD $6.50
Maybe it is just SuperSecretSimon-CustomMade LED. SSS-CM LED
I was able to get 2 minutes runtime from the M3 on turbo … on a bicycle, while I was in motion.
I had to switch it off, because someone appeared in the road, and I did not want to blind him/her :smiley:
Actually, id I don’t want to see very much ahead, but just avoid from overhead trees, etc, the High mode is just enough. I even put a lens in front of it to have a wider beam, which of course make the hotspot less bright.
On Simon ali store stated that “CREE XHP35 HI LED 4000K B4-40E” and 9998 available for bare
Are anybody have done measurment?
some are updated
remove it
[quote=d_t_a]
3 * LED in parallel
driver 22mm output 6A with tempareture management
seems not welcome,
i’m ready to design titanium AA flashlight with better driver
not only sst20
any 3535 LED can be installed
Simon, what’s the size of the MCPCB? Can similar sized MCPCB’s be found elsewhere??
uh,it’s just virtural number :person_facepalming: :stuck_out_tongue:
[/quote]
Anyone knows if this light will have a clean beam pattern with the 219B based on their experience?
Will the carclo triple/quad compatible model follow soon after the release of the reflector model?
Noice, so yep, can drop some sw45ks into that. 2A each is fine.
Thanks Simon :slight_smile:
Maybe someone managed to find a suitable TIR optics for Convoy S11?
Can you perhaps measure the reflector? I have a S11 on the way, might want to make a quad mule out of it.
