Like this light a lot. Thanks Lightbringer for reviewing it. Managed to open the bezel with 2 strap wrenches. No heat and just enough force. Seems regular glue was used so a little heat should help. I’m still debating whether to replace the main LED with 4000K 351D and the red to a 2200K 351B. I really don’t like red led but might need it someday.
I thought my desire for this light will pass as time passes by.
Unfortunatelly not.
I’m too weak to resist. Ordered.
But I don’t think I’ll use red light. I’ve read aswang has changed the red led to other. Hence my question: what instead? I mean which footprint (edit: figured 3535), voltage and amperage should I search for to replace this LED? I think I’ll go for some warm colors, 3000-4000K. Or 5000K but as a thrower, so without dome.
Any ideas which LED could succesfully replace the red one?
2700K SST-20 from KD is quite nice with BBL and below tint. If you want better throw and more lumens but lower CRI there are 5000K or 6500K SST-20s or maybe a dedomed xpg or xpl-hi. Its a small reflector though so don’t expect a lot of throw. I measured tailcap current for different modes with a regular multimeter.
White 0.01, 0.27, 0.88, 3.2 A
Red 0.02, 0.22, 0.84 A
UV 0.03, 0.5 A
So basically red has low med high and no turbo compared to the white led. Haven’t swapped mine yet since I realized it’s my only light with red led on it.
Another purchase is totally justified considering you’re a flashololic
So if there’s less Amps put in red LED, should I take something specific into account? Lowest Vf? Fewer Amps recommended by manufacturer? How about XP-G2 dedomed?
You could replace it with a second white LED, remove the wire, and bridge it to the lead for the first white LED to get more output on all white modes - the red mode just wouldn’t do anything.
This got me curious and I measured voltage on led wires. vf of red led is definitely lower at 1.8V in lowest mode. Did not actually know this since I’m not familiar with color leds. So I assume its using a buck converter but I’m not really very knowledgable with drivers so not sure what output to expect if you replace it with white led with higher vf.
395nm is fine for most things. Only certain substances need that shorter wavelength to fluoresce. Most things people would be looking at under UV (“pet stains”, scorpions, etc.) would fluoresce fine under 395nm.
I’ve even seen “UV” lights with just plain blue LEDs!
About the only thing that would make the light better (as in perfect ) would be a faint faint glow under the switch to be able to find it when it’s black out. Last night I was being killed by a mosquito, and when I’d feel my toe get itchy and then even go numb(!), it got away by the time I flicked on the light. Ultimately, I had to put my DC7 on moonlight to get the switch lit, and later turn on “breathing” :confounded: to be able to turn off the light.
Some company recently had a “night light”(?) function like that… forgot who, but I think I mentioned them elsewhere. I think VOB reviewed the light. Imalent?
Most backlit-when-off switches are either just too bright, or too annoying (eg, “breathing” switches). When you’re asleep, you don’t want a creepy “breathing” switch glowing at you. At least I don’t. And my Cometa’s switch is so bright I have to lie it down with the switch facing away from me.
Just a faint, red, barely perceptible glow would be perfect. That way you can grab the light by instantly knowing where it is, and know instantly where the switch is, too.
