I was able to get 2 minutes runtime from the M3 on turbo … on a bicycle, while I was in motion.
I had to switch it off, because someone appeared in the road, and I did not want to blind him/her
Actually, id I don’t want to see very much ahead, but just avoid from overhead trees, etc, the High mode is just enough. I even put a lens in front of it to have a wider beam, which of course make the hotspot less bright.
Simon would you consider manufacturing a P60 style host in 21700 format? The design in 18650 was flooded on the market. But now good host have nearly dried up and no one every built it in 21700 format. If a host was built to your quality standards I’d replace every P60 host I own now. SF compatible except tail cap, as body diameter is increased to 28-29mm’s.
