On Simon ali store stated that “CREE XHP35 HI LED 4000K B4-40E” and 9998 available for bare
Are anybody have done measurment?
some are updated
remove it
[quote=d_t_a]
Simon Mao: hodor:Any update on this beauty yet?
:partying_face:
This is a triple SST40 right? (I saw some mention of triple SST20…) Any approximate lumens numbers for this Convoy S12?
3 * LED in parallel
driver 22mm output 6A with tempareture management
Simon…any news about the titanium AAA lights?
seems not welcome,
i’m ready to design titanium AA flashlight with better driver
Triple SST20, IIRC.
not only sst20
any 3535 LED can be installed
oweban:Triple SST20, IIRC.
not only sst20
Simon, what’s the size of the MCPCB? Can similar sized MCPCB’s be found elsewhere??
jasontheguitarist:Do some LED bins only exist on paper? Seems that way.
uh,it’s just virtural number :person_facepalming:
Anyone knows if this light will have a clean beam pattern with the 219B based on their experience?
Will the carclo triple/quad compatible model follow soon after the release of the reflector model?
Noice, so yep, can drop some sw45ks into that. 2A each is fine.
Thanks Simon
Maybe someone managed to find a suitable TIR optics for Convoy S11?
Can you perhaps measure the reflector? I have a S11 on the way, might want to make a quad mule out of it.
Di_Joker:Maybe someone managed to find a suitable TIR optics for Convoy S11?
Гладкий/оранжевый отражатель для convoy S11, нижнее отверстие 7 мм. ➜ 194 заказов. ✓ Хорошие отзывы покупателей. ⭐ Рейтинг - 4.9 ⚡ Мы ускорили доставку! 【Скидки, купоны, промокоды】. Покупайте Портативные осветительные приборы по выгодной цене на...
I don’t have one either.
diameter 28.5mm
height 20.7mm
diameter of bottom hole 7mm
weight 10g
suitable for XML2 XHP50 XHP50.2
I measured it up ages ago when looking for options - I think I found a ledil and a carclo that would be close, but still not 100%.
Edit: from memory, the opening at the head is 25mm, in case you find a TIR with the “shelf” bit.
A mule with TIR optic? A mule is a flashlight without any optic.
KevinZA1988: Di_Joker:Maybe someone managed to find a suitable TIR optics for Convoy S11?
I didn’t say I want to install an optic. I want to install a quad MCPCB and a spacer, together with a lens and some film to diffuse the light a bit.
Would love if there was a spacer made to buy…
https://www.reddit.com/r/flashlight/comments/bei7cv/comment/el6xenm
Simon would you consider manufacturing a P60 style host in 21700 format? The design in 18650 was flooded on the market. But now good host have nearly dried up and no one every built it in 21700 format. If a host was built to your quality standards I’d replace every P60 host I own now. SF compatible except tail cap, as body diameter is increased to 28-29mm’s.
Kiriba-ru can make spacers. He just needs specs. And his prices are reasonable!
https://i.imgur.com/VPExcQ5.png (in inches, though)
