You could replace it with a second white LED, remove the wire, and bridge it to the lead for the first white LED to get more output on all white modes - the red mode just wouldn’t do anything.
This got me curious and I measured voltage on led wires. vf of red led is definitely lower at 1.8V in lowest mode. Did not actually know this since I’m not familiar with color leds. So I assume its using a buck converter but I’m not really very knowledgable with drivers so not sure what output to expect if you replace it with white led with higher vf.
395nm is fine for most things. Only certain substances need that shorter wavelength to fluoresce. Most things people would be looking at under UV (“pet stains”, scorpions, etc.) would fluoresce fine under 395nm.
I’ve even seen “UV” lights with just plain blue LEDs!
About the only thing that would make the light better (as in perfect ) would be a faint faint glow under the switch to be able to find it when it’s black out. Last night I was being killed by a mosquito, and when I’d feel my toe get itchy and then even go numb(!), it got away by the time I flicked on the light. Ultimately, I had to put my DC7 on moonlight to get the switch lit, and later turn on “breathing” :confounded: to be able to turn off the light.
Some company recently had a “night light”(?) function like that… forgot who, but I think I mentioned them elsewhere. I think VOB reviewed the light. Imalent?
Most backlit-when-off switches are either just too bright, or too annoying (eg, “breathing” switches). When you’re asleep, you don’t want a creepy “breathing” switch glowing at you. At least I don’t. And my Cometa’s switch is so bright I have to lie it down with the switch facing away from me.
Just a faint, red, barely perceptible glow would be perfect. That way you can grab the light by instantly knowing where it is, and know instantly where the switch is, too.
I really like the ’351 that’s in there now. It’s a nice creamy white, lit up everything wonderfully in my skeeter-hunt, and was almost as floody as my Cometa.
That candlelight ’351 sounds nice, but I’ve been using red at night for peeking at the clock, etc., to not ruin my night vision. Kinda eerie when I hit it full blast. I feel like a rotisserie chicken. :laughing:
I thought that with all the hoses, etc., you wouldn’t want anything particularly… abrasive… near them too much or too often.
I was thinking something along the lines of a stretchy rubber sleeve to fit around the narrower midsection. LuxPro lights have it embedded on their lights, and I’ve seen cheap AAA craplights with stretchy sleeves on them for texture/grip. Maybe even just as an add-in that someone could use or not as the case may be (like a clip, lanyard, etc.).
Welp, it was just a suggestion directed at MacLee's ^^^^ response as he alluded to an "upgrade". Wishful thinking on my part. Yeh, those little rayovacs AAA lights have that thin stretchy rubbery material that they use on the tubes. Works.
But OH, that tailcap on WK30 could use sumpin for sure. :-)
For the S2+, if you want a smaller light that takes an 18350 instead of an 18650, you can order the “shorty tube” to replace the come-with long tube.
The same way, if someone wants a knurled tailcap for the WK30, that can be made as an add-on, so someone can buy it separately (or it may be an option when buying the light itself).
That’s why I “noticed”(?) that lots of diving lights don’t have knurling. If someone wants to use the light on land, they can get the knurled cap as well.
OK, now I’m shopping for changes. Bought XP-G2 and Seoul Viosys UV 365nm Z5.
My plan is to:
- switch white to LH351D 4000K (yet from L4P) <— meant for close range
- switch red to XP-G2 de-domed / sliced <— meant for long range
switch UV 390 to Seoul Viosys <— meant for… ummm… nothing?
I wish all the modes had more amperage, but that seems way beyond my capability. Anyway, would you advice any changes? Is Seol UV good choice? Considering rather low power: is there any commonly available LED that could throw further with this Amps?
