The LEDs are probably ok in output even if they are the “chinese equivalent” stuff, go search here in BLF for the Rome Asahi Q30 thread, the light is supposed to be 3 x 70.2 but instead it’s chinese 7070. Even then, it’s decent output for that light for the kind of price (i was able to get it for just usd 44 or so, but still not low enough i was aiming for like usd 35 ), 7-8k lumens in a ceiling bounce, even if it isn’t a 21k lumens Haikelite MT09R. For sure you can push 7-8k out of a single Cree 70.2, but i am pretty sure that your lm/W efficiency would be way worse than even the “nasty” chinese LEDs.
All these stuff is really dependent on the driver and how much it’s pushing, coz as we all know you can run 50k lumens in a 1kg light underwater and there still would not be an overheating issue for the LEDs.
So 6 pieces, 15 pieces of the LED in the light it’s going to be the same thing unless they do spec a higher power driver/more batteries in the bigger light with more LEDs, then would it make a practical difference in real life.
And i suppose if you are doing some videography as well then the tint is reasonably important.
You might find some pictures in the reviews section in the links below to give you more info for reference.
I read that it’s about 6000 lumens in reality in one user review, so i suppose it wouldn’t be a 1000 lumen light.
At usd 37 for the links below, i think it’d be difficult to ask for more from the price. If you want more light, go for 2 or even more, nets you longer runtimes as well.
I had such light and it leaked on a first shallow 15m dive.
Salt water killed everything
It’s a lottery, some of my friends use it and they are happy….
Same trouble here. My leaked after 5 dives.I was able to save mine and found the the switch is poorly designed and allows water in.
I bought another light 6LEDs 9090, slightly different body style , more like one pictured with camera on previous post, and I took the switch apart and noticed that this light has improved switch. They added another silicone membrane to stop water from ever coming in contact with button shaft.
I use two of these , have about 40 dives with them up to 30m and so far so good!
Very bright, but fairly small and in comparison by far cheapest out there.
If you are looking for powerful light with wide angle beam , check the link below. I bought two of these and have about 60 dives with them and so far they perform well. Very reasonable price
Rec diver, your above #15 post includes a link full of unnecessary tracking information, all which comes after the question mark and the question mark itself is better removed.
However, the reason I'm telling you this is because the excessively long link you posted breaks the forum page layout, as it exceeds the thread box. Could you please edit your post and replace that link with one of the above? Thanks.
It does, tnx for the tip, now I’m just thinking if I should go for the one with more LEDs as most of the dives are done in mediterranean sea where we don’t have such great light conditions as in Carribean
I do believe that the 6x9090 LED model produces more light ( they claim 500W, probably less but very bright)
The light you were referring in your first post have 15 smaller LEDs but they rate these (120-180W equivalent) which would mean a lot less light produced. The 9090 LEDs are some of the most powerful out there.
The model with six 9090s have burning time 45min at full brightness with good Panasonic batteries.
With three modes you can easily adjust desired brightness and on low batteries will last more than 80 min.
A chap reviews the differences between the A11, A15, A10
I have the A15 and find it very good. From the other posts in the thread though I am wary about the clicky switches failing after more than a few dives.
As I posted in that thread, has anyone had any experience with the new type popping up now? COB Led versions
Only ~£30 i’m tempted to pick one up.
4 x 18650 as per the others, looks to be the same chassis just with a different led.
