XTAR PB2S
What is the standby current?
PB2 was terrible.
Patience, grasshopper.
I am starting to love the PB2S
Hope the price drops
Thanks for showing me the info about the low amps mode. Great!!
I walk the rice paper gently.
Lightbringer
So where did you get yours? I see Illumination Supply now has them for $17.52
The XTAR store.
Thanks
If anyone’s interested, I did a charge comparison against a wall charger and another power bank.
https://imgur.com/a/veExc6B
@UserM4 thanks!
The PB2S is already out of stock on Aliexpress. The owner told me the red ones should be available next week, the black ones will be delayed.
It is back in stock!
Just ordered a res one. Thanks for the heads up!
Does someone have first impressions of the magnetic latch? Are the magnets strong enough to hold it securely in place even when tossed in a backpack?
Yeah, you need to actually pry into the crease between door and body to open it. It’s not likely to just pop open on its own.
Illumn has been advertising QC 3.0 AND PD charging, but the official specs don’t mention a 12v output. Judging from the OP, I suppose it doesn’t actually support PD?
Check out this review as it talks about the 12v output
The cons are high parasitic drain, inaccurate display, batteries must be able to handle 2A charging
that’s not all the cons:
https://lygte-info.dk/review/Review%20Charger%20Xtar%20PB2S%20UK.html
5V-2,7A
9V-1,7A
12V-1,2A
Not full compatible with Quick Charge 3.0
I knew I forgot something.
Also expensive
