NEW SHARE
RD dual range 100v100A 7in1 OLED Multifunction Tester
[As always, everything is fast and high quality. I recommend to purchase.]
https://www.aliexpress.com/item/32788074155.html
NEW SHARE
RD AT35 5 digits USB 3.0 color LCD Voltmeter ammeter
[Item arrived in excellent conditions. Works as expected. Here is a comparison between the new model (top) and the old one (bottom)]
https://www.aliexpress.com/item/33022448123.html
NEW SHARE
RD UM34C Type-C DC voltmeter ammeter
[Cool tester. Checked its charging and wires, it turns out only one wire supports 2a. In general, i’m happy. The seller is well done, everything is packed on conscience.]
https://www.aliexpress.com/item/32880908871.html
NEW SHARE
RD DPH5005 Buck-boost power supply
[There was no doubt about the correct performance of this device, so that immediately mounted in the backup power supply. I am very pleased with the purchase, i recommend.]
https://www.aliexpress.com/item/32840324731.html
NEW SHARE
RD LD25 LD35 USB Interface Electronic Load
[Very fast shipping. Item received 7 days after placing order. The load works well. I like the fine current adjustment. The built-in display is handy and accurate enough for testing. I’ve already used it to test voltage drop on USB cables.]
https://www.aliexpress.com/item/32882318330.html
NEW SHARE
RD UM24C voltmeter ammeter
[Delivery is very fast. The quality is very good, the screen is clear and bright can be seen even in the sun. The version with bt is a convenient program for monitoring on the smartphone. I recommend the seller and the product.]
https://www.aliexpress.com/item/32845522857.html
NEW SHARE
RD TC66C Type-C PD trigger USB-C Voltmeter ammeter
[The trigger reached severodvinsk in 3 weeks. Packed well. Trigger in box, box in foam. In general, it came safe and sound. Installed on the phone the recommended program. Checked, works fine, bluetooth pairing with the phone. I’m happy. Seller and shop recommend.]
https://www.aliexpress.com/item/32968303350.html
new share
RD DPS3005 DC Step-down Power Supply
[I buy the second module, the first was more powerful-5015, but it took another device. As the basis of the amateur power source-the thing is wonderful!]
https://www.aliexpress.com/item/1000004279003.html
this is the last day of brand shopping day, every product is on discount, the price is lower than ever before.
if you have interest, you can click this link to view more:RD Official Store - Amazing products with exclusive discounts on AliExpress
NEW SHARE
RD HD35 Electric USB Load
[Before the mo for 12 days. for the organization of such logistics to the seller a big respect! I like the device myself. so i'm happy]
NEW SHARE
RD DP50V5A Step-down Power Supply
[Order not for the first time. High quality, fast shipment, good packaging. Buy, you will not regret! Seller thanks!]
https://www.aliexpress.com/item/32596330856.html
new share
DPS5020 power supply and its case
(non-communication)
[Nice body. Recommend]
https://www.aliexpress.com/item/32794029335.html
NEW SHARE
RD TC66 Type-C Voltmeter ammeter
[As described, works well, no complaints]
Hi just curious, is there any USB device out there that can measure the RMS and P-P value of a usb power supply noise, down to the 1mV resolution, without using an expensive oscilloscope? The measurements made by HKJ is always using a high-end oscilloscope. Was wondering is there is other ways to determine the noise of power supplies?
sorry, we don’t have
NEW SHARE
RD DP30V5A-L Step-down Power Supply
[I always put 5 to this seller, he is one of everyone who is interested in his products, and does not forget his customers. What can I say about the product is only good, these three understanding converters on the account of the 5th, 6th, 7th previous 4 work stably, perfectly what do I recommend? Sure!!! maybe I'll take a couple more, just in case of emergency.]
https://www.aliexpress.com/item/32639806678.html
NEW SHARE
[A little more than a month on the road, I received it at UkrPoshta, I ordered it not the first time, everything was clear, I checked it, it works, thanks to the seller, I advise the store ...]
NEW SHARE
RD AT35 5 digits USB 3.0 color LCD Voltmeter ammeter+HD35
[Nice gadgets. It can be used for measurements] https://www.aliexpress.com/item/33022448123.html
new share
RD DPS5005 Step-down Power Supply
[Thank. Corresponds to the description. I checked it works. The packaging is great. I recommend. Shipped fast.]
https://www.aliexpress.com/item/1000004290003.html
new share
RD DPS5015 Step-down Power Supply
[Delivery two weeks. Packed soundly, nothing crumpled on the way. It’s going nowhere easier, two identical cables, where to insert it is signed, you will not confuse. Works good. There are all the necessary protections: temperature, polarity. Various settings are set in the menu. The control is carried out by an encoder, convenient intuitive control. Even a child will understand. Even in this case, there is protection against children, which is turned on by a long press on the encoder knob. For my money, I think a very worthy device. The seller is sociable, quickly responds to SMS, answers all questions. Thank.]
https://www.aliexpress.com/item/32702714880.html
