best battery for the fw3a?
19 posts / 0 new
monkeyman77
Last seen: 1 week 9 hours ago
im about to order some but i want the best for runtime and output
raccoon city
raccoon city's picture
Last seen: 3 hours 16 min ago
The FW3A doesn't pull that many amps, so any of the quality unprotected flat top 3500mAh cells will be best.
raccoon city
monkeyman77
cool thank you
jasontheguitarist
Last seen: 5 days 18 hours ago
I have LG MJ1 flat tops in mine. The higher capacity is more useful than a brighter turbo that steps down in a millisecond anyway.
raccoon city
It's too bad GenuineCells doesn't sell batteries on eBay anymore.
I got a pretty good deal from them last year.
scosgt
Last seen: 1 week 3 days ago
I am so glad you asked this!
Maybe it is just me, but my new copper edition seems to prefer Orbtronics hi drain over Samsung 30Q. Going back and forth between them, it seems to get brighter (and way hotter way faster) with the Orbtronics.
Either way, battery life actually seems very good. After getting it so hot that I can’t hold it, when I put the battery back on the charger it still reads like 4.13
So it is not a battery eater, but you can’t really use it on very bright for long unless you hold it in an oven mitt.
mortuus
mortuus's picture
Last seen: 9 hours 44 min ago
i use 35E in mine good choice.
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
Musco27
Last seen: 7 months 5 days ago
Is it safe to try and use 2 CR123 batteries? I also just got an 18350 tube. Will a CR123 work in that? Just looking for back options in these crazy times.
atobe
Last seen: 14 hours 59 min ago
No to 2 CR123, probbly yes to a CR123 in the 18350 tube but capacity isn’t as high. Don’t blame me if it blows up.
ᕦ(ò_óˇ)ᕤ I can always be wrong, probably 75% of the time.
Musco27
Copy that. Thanks for the input man. I will try one cr123 in the 18350 tube. And post back.
forsh
forsh's picture
Last seen: 1 day 9 hours ago
ive been using samsung 30q in mine
but i recently just aquired a lumintop 3500mAh protected ,that came inside the torch when i ordered it. that has a max amp draw of about 4.5Amps
i think im gonna start finding lower max draw batterys and use them, the samsungs seem to be over kill
https://www.facebook.com/groups/163189738353433/?ref=share
Join my Facebook FW3/4/1 selling and buying group guys
Henk4U2
Henk4U2's picture
Last seen: 3 hours 14 min ago
Be careful! Protected batteries are NOT recommended, because they are too long!
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
forsh
forsh's picture
100695-B1-CD30-4-A60-9581-A1-C2-A90362-C2
william blake the clod and the pebble
I’m not how it’s been done but these are pretty much the same size
Henk4U2
Henk4U2's picture
Sorry, I just wanted to pass the general info on this light.
But it seems that some batteries are more equal than others.
forsh
forsh's picture
Henk4U2 wrote:
Sorry, I just wanted to pass the general info on this light. But it seems that some batteries are more equal than others.
no need to be sorry henk
it looks like some protected are quite a bit longer then others
i think iwas super lucky that lumintop sent me a 18650 by accident inside my light,
i was reading that lumintop has badged it themselfs and its some other type of brand, i would love to find out what brand, but for 6 euros for a 3500mAh battery its not bad for fw3a
max draw is only 4.5Amps though , but its enough for these lights
i love your knowledge henk and you are so generous
wle
wle's picture
Last seen: 17 hours 8 min ago
it just won’t go to the higher outputs, or run all that long
though it may run longer than some inferior 18350s
you could also use a 16340 li ion in the cr123a tube – if you want the least run time ever!
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
Musco27
Hey Wie, have you ever tried a CR123? Wanted to check in case so I don’t accidentally fry my light. It shouldn’t though right? Same power coming out right?
wle
wle's picture
i’ve done it with a BLF A6
it is ok because the volts on CR123A are under 3.2
it will never fry
just don’t try 2 of them!
and of course 16340 is ok because it is same volts, 4.2 max, as 18650 and 18350, just less current and energy
wle
-Greg Lemond.
