Today I got a third diffuser and tried it (with no problems) on the highest candle mode for a half-hour.
The diffuser is a foldable lantern from Towild. It is supposed to be made from food grade silicone. It is slated to fit 25 to 30mm diameter flashlight heads.
In normal use the diffuser did not fall off of my FW3A. It can be used tail or diffuser standing, and in a few depths / steps in either stance.
I saved a little money by getting it from the Aplustore on Amazon. Search, “Diffuser Tip for LED” if interested.
Another set of leds installed in another FW3A. I have been looking for the perfect tint with some real output when needed. The 219b’s are about perfect but the output is lacking and she gets really warm. I got in on BlueSwordM’s group buy for SST-20 FD2 4000k leds. I had the stock FW3A with the 4000k SST-20’s and a stock D4V2 with SST-20’s, the D4V2 looks just sickly green and the FW3A looked pretty darn good. This weekend I got the time to swap in a set of FD2’s and they look great and as an added bonus it appears to me that the early stock SST-20’s used this same led! I think someone else somewhere reported the same thought, I would concur 100%.
Now, there may be some better bins of SST-20 4000k, but the question is… will mere mortals ever see those bins? I would still like to get ahold of 3 of the rosey LH351D hi cri leds, but not sure that will happen either.
Just received the 219C purple version from Illumn. The finish is so beautiful. Perfect gift for the ladies! Here are some measurements:
At turbo using P26A cells with stock carclo and lens:
lumens: 2,180
CCT: 4105K
DUV: 0.0029
CRI: 91.0
R9: 56.4
Rf: 88
Rg: 96
At low output using P26A cells with stock carclo and lens:
lumens: 53
CCT: 3994K
DUV: 0.0033
CRI: 92.9
R9: 68.3
Rf: 88
Rg: 97
It is noticeably more green that the SST-20 4000K version at all levels. With just a slight bit of extra output, I don’t see any reason in buying the 219C version instead of the SST-20. I bought this just for testing since no one posted any test results on the 219C version thus far. Will not get any more 219C version lights unless the manufacturer can source the rosy 4070e bin 219Cs.
TY. It’s all etched with a tiny bit of 800-1200 grit wet/dry work and a little polishing. If you do it in several layers you can create more depth and shadowing in the look of the design than there is.
Ferric Chloride! TY! The clip is softer steel so it will etch quicker. I sealed the button off (underside) on some electrical tape and sealed the edge with fingernail polish so the tolerances for fit/use weren’t etched at all. I also left the bend and hole of the clip out of the FC other than a quick dip for color.
