Kiriba-ru made me 2 versions of the S11 spacer based on the dimensions posted to the Reddit thread. One was pure copper, the other was a copper core with a brass support ring to keep the optic in place.
Dare I ask how much it cost?
I like the looks of the S12, that tailcap
How does the beam look versus triple TIR, e.g. Carclo?
Very welcome updates to the other two as well!
S12…
What a beauty
My precious…
I would really like to see a beamshot of the S12… Very interested in one!
Very interesting MCPCB though… might look into sense resistor mod for it too cause more than 2A per emitter would be good.
will the S12 fit the Vapcell 4500/ Lishen LS21700SF cells?
Please add a picture comparing the size to a S2+ and the 18650 equivalent in case of the M21B.
M21B equiv is M1/M2 (unsure exactly which but will work out soon)
It says “inner diameter 22mm” so I think it will fit
S12 and M21B don’t have temperature protection?
What do you think is better - SST20 4000K or 219C 4000K?
I think they will have temp protection. It’s the new linear Convoy driver.
That M4U…. wtf. Side switch light running Biscotti? How?? Unless they have adapted the firmware to be used with an e-switch.
any info about the UI on the S12? Would be nice to know if it uses regular attiny and it’s possible to flash Crescendo
Equivalent is the M1.
Anthon:will the S12 fit the Vapcell 4500/ Lishen LS21700SF cells?
Please Simon, add 1mm more room for the cells in your 21700 lights :money_mouth_face:
The inner diameter of my L21A is 22 mm as well, Samsung cells fit, but Shockli cells did not fit.
Adding 0,6 mm will make a lot of difference, or the cheaper manufacturers could just produce cells that comply with the standard 21700 = 21mm x 700 mm… :person_facepalming:
will new lights be sold on banggood ?
Wasn’t the S12 meant to have Crescendo?
Why simon didn’t include the battery option while the store is selling battery?
I think its similar like the BD02 with reverse-clicky (Omten 1288) side switch, as you can see here: https://www.taschenlampen-forum.de/media/albums/convoy-bd02-treiber-mod-und-led-wechsel.1895/
