Snap. I bought the Ti LAN because of the driver. Now I don’t even want to use it for fear of damaging it :person_facepalming: . It’s one of the most expensive light I have.
Great release. I hope Simon will continue to expand!
Yeah I agree, 6A Biscotti would’ve been nice. Or even just one or two more low brightness levels.
If he makes just 100% after 2 or 3 click, then there could be 4 regular modes and 1 “turbo”. Then make temp. limit to 65 degC and ability to disable memory and it is all I want. And I guess most of us.
I really dislike mode memory, so these are not for me.
\quote=Simon Mao]
Simon…any news about the titanium AAA lights?
seems not welcome,
i’m ready to design titanium AA flashlight with better driver
[/quote]
That’s a very sad news. Nevertheless I wish you luck with it.
I only ever want mode memory on e-switch lights where there is also a shortcut to at least moonlight, and preferably turbo or even more like on Anduril and Zebralights.
:+1: Reylight has the best AA driver followed by Sofirn SF14 that I’ve seen to date and I own several dozen AA flashlights.
I really wish to find AA driver as good as Reylight’s.
Rey sold a few in the past but not anymore.
will the S12 fit the Vapcell 4500/ Lishen LS21700SF cells?
yes, inner diameter is 22mm
the diameter of vapcell is 21.7mm
Simon Mao:Please add a picture comparing the size to a S2+ and the 18650 equivalent in case of the M21B.
That M4U…. wtf. Side switch light running Biscotti? How?? Unless they have adapted the firmware to be used with an e-switch.
it’s not e-switch,it’s 1288 switch soldered on driver
any info about the UI on the S12? Would be nice to know if it uses regular attiny and it’s possible to flash Crescendo
not successful to apply Crescendo,but manufacturer gave me a 7135*14 driver sample with UI similar to Crescendo
Mocarny: Anthon:will the S12 fit the Vapcell 4500/ Lishen LS21700SF cells?
Please Simon, add 1mm more room for the cells in your 21700 lights :money_mouth_face:
It says “inner diameter 22mm” so I think it will fit
S12 and M21B don’t have temperature protection?
What do you think is better - SST20 4000K or 219C 4000K?
The inner diameter of my L21A is 22 mm as well, Samsung cells fit, but Shockli cells did not fit.
Adding 0,6 mm will make a lot of difference, or the cheaper manufacturers could just produce cells that comply with the standard 21700 = 21mm x 700 mm… :person_facepalming:
uh ,L21A is 21.5mm,friend
will new lights be sold on banggood ?
yes, will be sold on BG soon
Why simon didn’t include the battery option while the store is selling battery?
not convenient
which country do you live in?
Yokiamy: Mocarny: Anthon:will the S12 fit the Vapcell 4500/ Lishen LS21700SF cells?
Sorry, my bad :person_facepalming:
I saw a P60 mentioned… I do wish there was an affordable 21700 P60 light out there. I use many of them for sane output lights, granted they do not make great hot rods but I do not always need a hot rod light.
Any chance Simon?
I just remembered, don’t the new 6A drivers use forward clickies?
Hey Simon,
I was just reading the discussion in this thread Who can build me a Custom UV Emisar D4? and it was mentioned the Convoy S12 might make a great host for 3 x LG UV 365nm LED LEUVA33W70RL00.
Could you add the LG UV’s as a emitter option for the convoy S12?
And possibly sell a Zwb2 UV pass filter that would fit the S12?
Any chance Simon?
I am not sure if the P60 has a patent for appearance.
Hey Simon,
I was just reading the discussion in this thread Who can build me a Custom UV Emisar D4? and it was mentioned the Convoy S12 might make a great host for 3 x LG UV 365nm LED LEUVA33W70RL00.Could you add the LG UV’s as a emitter option for the convoy S12?
Regarding UV flashlights, I don’t know if the user needs narrow beam or wide beam.
and S12 has wide beam.
the second problem ,it’s too hot ,And the heat resistance of LG UV LED is not good.
i will have C8 with LG UV available soon,the beam is narrow
