A limited number of models are in stock of the FW3A Color Anodize and FW3T, most pre-orders will be shipped by Monday, following SKUs arrived late Friday:
FW3A OD GREEN CW
FW3A OD GREEN NW
FW3A OD GREEN SST20
FW3A PURPLE CW
FW3A PURPLE NW
FW3A PURPLE SST20
FW3A PURPLE NICHIA
FW3A BLUE CW
FW3A BLUE NW
FW3A BLUE SST20
FW3T Nichia
FW3T CW
FW3T NW
FW3T+C NW
FW3T+C NICHIA
Just received in today’s mail an FW3A TK special I had preordered from Illumn. Works perfect I wouldn’t expect anything less from Calvin & Bro.
Now how the H311 do I get that danm black retaining ring out of the tail cap? I WILL have that swirly switch cap for my Copper one before gifting my wife with this Barney one.
I was able to work the retainer ring out using a very small flatblade screwdriver in the cutout area. I now have a swirly switchcap on my FW3C and I replaced the silver clip with a black one. So much mo’ betta’ Now iffn that turboglow gasket in lava would show up from China. I should have ordered from Calvin&Bro….still may as I think the lava would compliment the Zinfandel colored FW3A also.
Received my purple 219C FW3A and lava color glow gaskets among other stuff I ordered from Illumn. The metallic purple is really good looking. The lava GITD gasket is also very bright and color is excellent! I posted my test results of the 219C here.
I just tested 8 NCR18650GA that I bought from Illumn.com
I tested the discharge capacity and it is the highest capacity batch of NCR18650GA I’ve seen and the highest capacity 18650 cell money can buy at the moment. Get them before this batch sell out.
I tested the Acebeam 16340 550mah from Illumn and got 657mah. The same cell that came with the Acebeam TK16 measured 617mah. This is the best high current 16340 on the market. I highly recommend it if you want the highest output. If you want the highest capacity but still higher current than most, get the Vapcell 16340 800mah.
