Interested in C8 21700 Sand XHP 35HI. Thank you
Kind of dilemma here which emitter to choose. With that size format, I believe both SST40 and XHP35 will have almost identical output, being driven not as hard as they possibly could be. I dont care for the extra throw of XHP35, as the reflector of this model is rather small anyway. What matters to me is the driver and ability to run turbo and high mode with almost empty battery. Here I would expect that XHP35 having a boost driver would be able to do so. Can someone confirm?
hi freeme, interested in C8 21700 xhp35 please!
Package includes MARCH C8, lanyard, spare lens, thread lubricant, spare tail switch, 4* o-rings, and 2*18650-to-21700 silicone converter.
Can you please get more info on the drivers of SST40 and XHP35 versions? Would like to know if the XHP35 can use high/turbo mode with almost empty battery, as it is a boost driver. Also any chance of getting these in neutral white?
Interested in the C8 21700 sand, SST-40, OP reflector.
Will this be a Banggood deal?
Interesed C8 XHP 35 HI (21700)
Also interested in C8 XHP 35 HI (21700)
whats the lumen output on highest on the emitters?
Interested in C8 21700 w/ 50.2 in any color
MARCH C8 XHP50.2 (CW) / 2246.9lm / 21700-48G / 6.45A
MARCH C8 SST40 (NW) / 1975.7lm / 21700-48G / 6.2A
ASTROLUX FT03 XHP50.2 / 4060.7lm / VTC5A / 9+A
Based on my initial test result. We have decided to proceed to stock up XP-L HI and SST40 first.
thanks for numbers.
Group buy will start within 24hrs.
20mm indeed, just like your regular C8. Also there's no thermal paste, but some white thermal glue.. (and the 2 screws holding the MCPCB)
Interested in the NW versions.
Oh damn it, why thermal glue?
Haven't tried swapping the emitter so far, but that thermal glue doesn't look so strong. It's more like an old solidified thermal paste and it kinda chips like a very hard and old piece of cheese.
Thank you
Quick inspection.
Interest
