The difference is black and white (literally, just look at the LED base)
Compared the LED base with that from Azhu’s sw35 and is identical.
Add me for 15 sw30 r9080
Thanks
Yeap, could take 10 of each
UPDATE: So in regards to the 219c, right now only the sm403 bin is available. None of the other options are in stock. I’ve requested to be notified in case they ever do become available. I also made a mistake and didn’t realize that the sm4550e and sm4570e bins don’t come in 90+ CRI so they will be dropped out of consideration.
219b sw30 and sw35 are still likely to happen. Will keep you guys posted on those as more info becomes available.
Thx Andy
EDIT: if 219C is out of the game then i’d like 10 x sw35 instead
Well, since the 219C fell through, put me down for 6 of the 219b sw35 r9080’s.
UPDATE: sw30 and sw35 r9080 will arrive on 9/3.
By the way, I flowed SW40’s in my FW3A and SW45K’s in my FW3C. Carclo 10511 optics.
SW40 - not a hint of green, pure white tint, gorgeous color rendering.
SW45K - beautiful white tint with that magenta rosiness, gorgeous color rendering.
On turbo, both go more rosy, but nothing like the big tint shift with SST-20’s. I prefer these even if they have less throw. Not even white wall hunting can fault these emitters in my setups. Thanks Azhu! Looking forward to the next batch!
Could not agree more, I have SW40’s in one of my FW3A’s and SST-20 FD2’s in my other pair at the moment. The FD2’s are pretty darn good as well.
Could you post beam shots of the sw40 next to the sst-20? I’m curious to see the difference.
I will, I had them all taken but my memory card seems to have crapped out. I do still like the sw-40 better, but really only for wall hunting. The FD2’s are really good. There is the smallest hint of off color at very low to moderately low drive current. At mid to high current they are just super!
I will shoot the set again this weekend if I can’t recover the images. The most telling is when comparing the D4V2 SST-20 to the FW3A SST-20 FD2. I will shoot with a fixed daylight white balance and with a close white balance of 4000k.
I may also build one with SW-45k’s this weekend to add to the comparison.
Please put me down for:
10x sw35
10x sw40
With shipping to Canada.
Thanks!
LABOR DAY SALE! Nichia sw40 are only $3/ea! Ends Monday 9/2.
Nooooo! The dreaded sale-on-something-I-just-bought!
I’ll be ok, I’ll be ok.
Good luck.
Good luck.
Haha don’t you just hate that? Good news though, you can buy more so you don’t feel left out!
Does sw45 and sw45k have the same CRI?
I dont know the full technical answer to your question, but imho, the sw45 and sw45k are essentially identical in CRI and only differ in tint, the K being more pink
here is info with charts by maukka on various LEDs that you may find helpful also
https://www.virence.com/product-page/nvsl219bt-v1
Here’s the data for the following emitters (links to a screenshot with lots of CRI data measured from the hotspot): NVSL219B-V1 sw45k NVSL219CT sm273 NVSL219CT sm303 NVSL219CT sm353 NVSL219CT sm403 NVSW219CT sm503 NVSW219CT sm573 NV4L144AME sm453 NV4L144AME sm503 NV4L144AME sm573 219B and 219C were measured at 700 mA, 144 at 1400 mA. I have tabulated the results using both a diffuser (Convoy) and a reflector (Reylight Pineapple one for the 219B/C and Nitecore TM03 one for the 144) […
Since the SW45 has a better chance of being on the BBL I would suspect on average it would have a higher CRI.
