【convoy】H4 and B35AM options are updated
I really wish to find AA driver as good as Reylight’s.
Rey sold a few in the past but not anymore.
yes, inner diameter is 22mm
the diameter of vapcell is 21.7mm
it’s not e-switch,it’s 1288 switch soldered on driver
not successful to apply Crescendo,but manufacturer gave me a 7135*14 driver sample with UI similar to Crescendo
uh ,L21A is 21.5mm,friend
yes, will be sold on BG soon
not convenient
which country do you live in?
Sorry, my bad :person_facepalming:
It seems i already have measured it myself
I saw a P60 mentioned… I do wish there was an affordable 21700 P60 light out there. I use many of them for sane output lights, granted they do not make great hot rods but I do not always need a hot rod light.
Any chance Simon?
I just remembered, don’t the new 6A drivers use forward clickies?
Hey Simon,
I was just reading the discussion in this thread Who can build me a Custom UV Emisar D4? and it was mentioned the Convoy S12 might make a great host for 3 x LG UV 365nm LED LEUVA33W70RL00.
Could you add the LG UV’s as a emitter option for the convoy S12?
And possibly sell a Zwb2 UV pass filter that would fit the S12?
I am not sure if the P60 has a patent for appearance.
Regarding UV flashlights, I don’t know if the user needs narrow beam or wide beam.
and S12 has wide beam.
the second problem ,it’s too hot ,And the heat resistance of LG UV LED is not good.
i will have C8 with LG UV available soon,the beam is narrow
Simon, any chance of beamshots of the S12?
Hooooo boy UV C8 :o :smiley: OP reflector though!
Thinking I’ll grab an S12 soon and resistor mod it to 8A or so if I can find anywhere to get R040 in a mix-kit… don’t need 50 of them heh!
Oh yeah, Simon, will the 17mm and 20mm driver adapters work in this light? Is there enough thread on the driver bay??
Hello Simon,
Any chance for the M21B host version?
If it’s still single mode, I think a forward clicky would be great
Patent issues with the clones was on the dropin pocket size. The solution was that Solarforce and many others increased the pocket dimensions. Now needing that additional spring around the pill. However appearance is up to the creator. Your S12 tail cap and battery tube portion would be a nice style that’s yours. Then a dropin pocket added on top. But please keep the head threads standard for all those custom heads. Personally I would buy at least 10 to upgrade run times on most of my “around the house and car P60’s”. Granted the style and function might be dated, it’s still the one loved by many. It’s the only host I use to build lights for my fellow officers in my area. Mostly 1 to 3.8 amp dropins were heat is not an issue. The flexibility of swapping dropins allows the same light to work patrol, currency verification, organic detection, etc. If a little extra attention is made to the tail cap and double o-rings on the head and body to keep that high level of water proofing, great. I prefer simple always working duty lights without electronic switches or charging ports. It’s always been a P60 from Surefire or Solarforce on my duty belt for the last 15 years. Some newer lights are brighter but none are better.
