That was too easy, I just moved the O ring up to where it belongs, and Viola!
All is well, no more exposed O ring.
fwiw, that light has a kaidomain reflector and a non stock mcpcb installation. I dont know how thick, the mod done by a friend.
I just changed the optic on my triple sw45 from pink panda. It now has the narrow clear and is making 410 lumens on a 16340… it was 360 with the diffuse optic.
I really like the narrow clear.
I also added a touch of nyogel 767a to the control ring assembly, and then sealed it up with some blue locktite, after swapping the driver to one of the new 2019 RRT-01 drivers, that has strobe.
The ring feel is even nicer than before… can be fine tuned with one finger, but has enough damping that it wont move unintentionally.
There is still the slightest grinding feel of the detente ball moving in the track but the rotation is nice and smooth. The off detente is snappy too. I can really feel it lock in, and it takes an intentional effort to turn the dial on. Then it rotates nice and easy, without being too loose nor too tight.
Im super happy to be learning how to lube the control ring for a good “feel”, to my taste.
Major respect to pinkpanda for this triple sw45 Original RRT-01… what a beam!
And thanks to CRX for the glow gaskets… I like the AcquaMan!
What a beautiful Light! thanks to all my friends on BLF for helping me get here
I was thinking about this, from another thread:
Good idea!
fwiw, when pinkpanda built those triple RRT-01, he also modified the optics to fit the RRT-01 head opening, which is smaller than necessary to fit a stock optic.
Im not sure if pinkpanda also reduced the size of the triple mcpcb to fit… seems likely… he did a ton of work without mention of reward, out of kindness towards the BLF community
I just stopped by mtn to see the size of the triple mcpcb, but I dont know yet what the size of the opening is in the head of the RRT-01
I note mtn also has spacers… wouldnt it be cool if one of them fit the RRT-01?
maybe someone (pinkpanda or moderator007) will chime in with some measurements on spacer size for RRT-01, compared to what mtn offers
I dont mind doing a bit of sanding… lol
like I did to fit the glow gasket
and for an encore, I would like to see trit slots through the fins of the Eye10 head. So that finned piece can be moved onto my PandaBuilt Triple sw45, Original RRT-01.
Trits would be groovy…
I will need to take some measurements to double check the exact ID of the rrt-01 head but I’m sure the MTN spacers are too wide - 20.3mm. For reference the diameter will need to be the same as the reduced size of the mcpcb (roughly 15mm going by the comments above).
Edit - also I think Geuzzz was intending to remove the glass and use an unmodified optic for the ‘relatively simple mod’
This info is for the older RRT-01.
The inside of the head where the heatsink would fit measures .660”.
The height of the heat sink would need to be .295” if the factory lens is to be installed. IMPORTANT
The height measurement for the heatsink is from the bottom of the led shelf. In all the RRT-01’s and TCR1’s I have seen there is a small cut out in the bottom of the shelf to fit the mcpcb that is smaller than the head opening where the heatsink would set. The bottom of the heatsink will not touch the bottom of the led shelf because of this extra little cut out where the mcpcb sets (a little lip). I bore all my triples out first and cut the extra lip of the bottom of the led shelf making it all flat before making the heatsink for good fitment.
If you made the heatsink height smaller to account for the space where the heatsink is setting on the lip instead of the led shelf, it could still work allowing heat to travel to the head out the sides of the heatsink. It wouldn’t be as good as setting on the mcpcb shelf but it would probably still work.
Without boring the shelf flat and getting rid of extra lip, the heatsink could be made with that extra lip cut into it. I don’t do it this way so I dont have any measurements to help with that.
If you didn’t use the lens just add the lens height to the .295” heatsink measurement and that should take up the space.
The bottom of the mcpcb shelf should be around .600” (15mm mcpcb with clearance). So that leaves .060 from my .660” head diameter measurement. That means the extra mcpcb shelf lip is about .030 in width. The top of the head where the reflector sets is actually bigger than where the heatsink would set. It has a lip at the mcpcb shelf and another about half way up the head where it increases in diameter at each lip. The top half of the head is bigger than the rest this allows the optic to fit with shaving.
If you can make the right size heatsink, the optic and triple mcpcb can be filed down to fit. I filed the first one I made, the second one I cut on the lathe. Can’t really tell any difference, the lathe was just easier.
Most of the heatsinking goes out the sides. The reason I made it that way is because I wanted to make the mod 100% reversible to stock. Rather than drilling another (5th) hole through the led shelf for routing the led wires I made a pocket under the spacer for the wires. This light is no hotrod so I wasn’t worried about the best possible heatsinking (I can’t see it making a huge difference anyway). Note - the height of this spacer is to suit the modified optics I did. I don’t know what height you would need to suit unmodified optics.
I measured the KD triple optic last night at .243” from the top down to where the legs would set on the mcpcb. That’s the total height installed not the actual height including the legs…
On my heat sink, I drilled the triple mcpcb center hole half way thru the heatsink and then marked and drilled the wire holes from the mcpcb shelf at a angle towards the center hole I just drilled. Both wires run up at a angle and met in the middle. The heatsink sets flat on the mcpcb shelf.
I suggested to the seller that he post his offer for adoption, to the RRT-01 Triple LED group buy thread that pinkpanda links to above. Im available to answer questions and to share info about glow gasket and control ring packing upgrades…
since I put some nyogel 767a into the control ring of my pandamod triple sw45 Original RRT-01, it has been dialing buttery smooth… its a joy to use
theres a bit more to it… nothing is “just” a simple repack… a repack moves the light into a whole new quality level of ring feel… think, buttery smooth, like a nikon lens…
details like including working in extra lube around the edges of the ring, and spending quality time fidgeting with the ring… etc… will burnish the contact areas to eliminate gritty spots and create a deliciously smooth, one finger dialing experience. Don’t forget the locktite
has a list of most of the parts used to mod the Original RRT-01 into a High CRI Nichia configuration. Also, as a reference, It also links to the spacer dimensions for a Triple LED mod here… I hope it helps people mod the Original RRT-01 host with some nice LEDs, beams, and dials. Rumor has it the RRT-01 is makes a great Dad Light… iow, very muggle friendly…lol
equal time
the New 2019 RRT-01 also is being built as a triple, scroll back a page to see a nice one…
thanks to your information I have done two group buys and purchased a total of 30 NOS Original RRT-01 light. They are being redistributed through BLF membership internationally, including Singapore, Germany, Holland, Croatia, Great Brittain, Australia, and USA
You can blame me for being the head instigator, but I stand on the shoulders of giants that have contributed skill, research and info about modding parts and supplies. Two of the standouts are pinkpanda and moderator007, to whom I remain eternally grateful for your sharing information, support and encouragement.
Others I credit, with respect, for helping me appreciate the unique benefits of the magnetic rotary UI, include Archibald Tuttle, Tip and Ring, and Fireclaw18
I also want to thank MascaratumB for starting this thread, whithout which I would not have been led to purchasing my first Original RRT-01, thanks to a kind BLF member classified.
there are many more people I could name, most of them are in this thread, that have been kind and helped me with support and encouragement, and some even sent me money… lol
thank you all for the community effort to bring more Rotary lights into circulation
about brass
what cools better,
copper star to aluminium pill, to titanium body (tcr-1)
or
copper star to brass pill, to aluminium body? (2019 RRT-01)
about lvp
I just tested 2019 RRT-01 driver w triple sw45:
I used depleted cr123 for the low voltage tests
440 lumens @ 3.8v 18350
380 lumens @ 4.0v 16340, I also get 380 w single sw30
170 lumens @ 2.8v CR123
15 lumens @ 2.6v CR123
there was no LVP,
the light just steps down to whatever it can do at any given voltage
but there is plenty of visual warning, by dimming and brightness step downs of the light.
more and more of the dial on the high end of the scale becomes non responsive, and creates no change in brightness
by the time the voltage is below 3 volts, the light is half as bright as on a full charge. I notice that.
a less experienced muggle, would notice the light when its only putting out 15 lumens, and that would not be below 2.5v…
so, for an operator who literally is not asleep, the dimming is obvious, before the battery is in serious overdischarge voltage, below 2.5v
I did not see the flashies you found at 3.0v, just step downs
but I liked learning that the light is going to have to get ridiculously dim, before Im in overdischarge territory… cause I like to use 18350 and only unprotected fit the Original RRT-01
Sure , I was jus referring to the time it was created and with no further replies
With be old batches being sold currently, jon_slider courtesy, I figured there would be some other stuff related to these lights around !
I would only be interested in an extender to use it with 18650s (like these: Sold: Jetbeam RRT-01 18650 extender tube) , not a whole tube. I actually managed to use it with a Convoy or Sofirn tube, but it isn’t water/dust proof :zipper_mouth_face:
I need some help. Don’t have my2019 RRT01 with me and i’m about to order some stuff from KD but i left the notes with ’19 RRT reflector size.
If someone can take meassurement of new rrt reflector that would be great.
Wanna get OP for my other mod.
If it’s posted above please excuse my lazyness.
It was about time to post my poormans 2019 RRT triple mod.
Since i’m not a man of photos i only have 3 of them but you’ll get the idea
First, open and disassemble the head as already posted many times. Remove the driver and MCPCB.
I have used replacement driver from Jetbeam which has longer led wires so instead of soldering extra length needed for triple build, i had to cut them.
Open first beer and start filing 3UP MCPCB…
Since i didn’t meassure anything i had file and check physicaly fitment in the bottom of upper part of the head (see photo)
After 3rd beer MCPCB with emitters was ready for thermal adhesive (glue) and to be installed in the head. I have Phoby2, 2-component epoxy.
Next day i’ve stuffed the original led board opening in brass portion of the head with thermal pads which can be found in KD store (don’t have a link now)
Now Carclo 10507 was about to be filed which i did, again few beers helped me and at last i had a correct size for installatio.
Please note that neither MCPCB nor Carclo were perfect round circle due to hand tools!
Once you tighten the head back on the brass section, the only thing that’s left is soldering led wires, installation of Carclo, original lens oring and lens (with the bezel ring).
And that’s it.it can be done in few hours (1-2h) but alcohol and wife were crucial factirs not to.
Thermal pads are transfering heat from MCPCB to the bezel since i didn’t have heatsink at that time. MCPCB in this build seats high above brass section, in the bezel.
I have to add that one member shortly after sent me machined alu piece according dimensions of the section where stock led board seats and is to be installed when bezel and barss are connected. And of course i didn’t took a picture and i just realized i don’t have optics photo…damn it.
I believe most of you are familiar with the tasks required to be done once you see pics but if any info is needed, just shoot.
Oh yeah, if someone can post dimensions of stock 2019 RRT01 reflector that would be great.
