Hardware looks great, start will the software be like? Well it support logging?
And what about the price?
Looks very nice, hope the price is also nice. I have a DC supply just waiting for something like this, output 13 amps at 48 volts.
Nice! I hope you’ll also make a smaller case for use with external AC-DC power supply.
I like it, what is the expected price going to be around?
the price is not confirmed now and we need final test, and I will publish a new article to introduce the function and price when everything is settled.
for PC software , it have added more function than old PC software, also have logging , don’t have
it can have function to charger battery …
it will have many many function
and it will be released in a month, please wait and you will be satisfied with it. we designed it based on the advices from our customer
the price is not confirmed, we need to test the quality first, and when all these things are settled, I will tell you the price and the function, also I will make a video on youtube to show you the function
it is a standard case, the case and power supply can be bought seperately, so you can DIY the case
You currently have 23 separate threads (http://budgetlightforum.com/user/20499/my-threads) about your company products, do you really need to open a new thread for every new product/review?
That looks really neat for a DIY laboratory power supply. You say it needs to be powered by a standard CV power supply. Specifications? Is the module boost capable or buck only? What are its output limits, 60V and 6A? Size? Target price?
ok. I will consider, but you can see each article is different, I don’t just introduce the product, actually it only takes a small part, I use them to test other charger/power bank/ cable, I teach the methods to other people how to test the quality of their device, the method is useful even if you don’t use our products.
it is a still buck power supply, and it can provide 60V/6A output, and the display part is about (16.5*8*3.5)cm. the case (31*17.2*8.7)cm,the size may be adjusted so it is only a referance. the price is not settled, they need final test to make sure the qualtity can be promised, when the price comes out, I will let you know
In the case of a commercial entity that posts on BLF, you should follow these rules for commercial sellers:
IF YOU ARE A COMMERCIAL SELLER:
- Please make only a few threads in the Commercial Sellers' Spot category.
- If in the future you want to let us know about new products and offers, please make update posts in the same few threads. For example, you could create one thread called "CompanyXYZ.com New Flashlight Products" and another called "CompanyXYZ.com Current Offers and Coupons".
- Affiliate links to your products by your customers should only be placed in the BLF User Negotiated Deals category.
- If you want to do a completely free giveaway, please post in the Giveaways and Contest category.
- Please introduce your company and clearly state that you are a commercial seller.
- Please be polite, respectful, honest and forthcoming.
- Please DO NOT make commercial posts in any other forum categories except the Commercial Sellers' Spot.
- Please DO NOT make commercial posts in the Want to Sell or Group Buys categories.
- Please DO NOT abuse your privilege by making many different threads in the Commercial Sellers' Spot.
- Please DO NOT make commercial posts about products that are not related to flashlights or flashlight accesories.
- Please DO NOT post about your company in other threads unless users specifically request information from you.
- Please DO NOT pretend to be a happy customer of your own store.
- Please DO NOT ask questions about your own products.
- Please DO NOT create many different user accounts.
- Please DO NOT send advertisements via the BLF private message system.
- Please DO NOT create contests or giveaways that require posting links to your website.
- Please DO NOT create contests or giveaways that require purchasing something to participate.
- Please DO NOT be rude, pushy, or annoying.
6006, so maximum output is only 6A?, not enough for LED testing
If they can make 6020, and limit power output to 500w, i will be very happy to buy it
I was going to say sort of the same a while ago. While 60V is plenty, 6A is definitively too small.
this is the first one of new series, like DPS5005—DPS5015—DPS5020, if customers like this kind of power supply, higher voltage/current version will be published
ok, thank you for explaination
hello guys, there is one thing I want to tell you: RD tech new power supply RD6006 has been released!!
RD6006/RD6006-W Product link: https://www.aliexpress.com/item/4000282551930.html
And we design two cases(S06A and S06D) for it, here is the link:https://www.aliexpress.com/item/4000284522671.html
www.youtube.com/embed/fn6ROhGrLtI
Price: as old rules, when the new products are published, we will set the lowest price
RD6006: 47.68 USD (normal price 55 USD), RD6006-W: 51.18 USD (normal price 60 USD)
S06A: 28.43 (normal price 33 USD), S06D: 18.81 (normal price 23 USD), Time is limit, please seize this chance.
here are some introduction pictures, if you want to know more information about RD6006, I suggest you to check the product page, I write everything there, welcome to ask me if you have any questions.
Questions… so this unit is rated for 360 watts, but lists a max amps output of 6 amps. 360 watts = 6 amps @ 60 Vdc. So, can the unit be set for 4Vdc and 15 amps or is 6 amps a hard limit at any voltage? If that is the case, it is not large enough for LED testing. It would be nice to see the input at 48-60Vdc and the output at 15 to 20 amps.
I would definitely use the wireless PC control, that would be super handy as I always have a laptop on the bench or an android device. Power supply could be located under the bench, out of sight, out of mind.
Hard current limit.
The DPS5015/20 is for you then,
