Low-cost copper pills, spacers, optics, drop-ins (Updated 23/10/2022))
No plans. I need to sell stocks.
I will think how to modify C8TT for modern hosts.
I dont think 12 led series module is suitable for flashlights.
Good eye, I saw a “P” on the board but it’s actually 6S2P or 12S
I have got several requests for S11 quad spacer set. I think I need to make small groupbuy.
Since Im trying to minimize my stocks (both parts and materials), I wont make many extras.
Im out of 30mm Cu rod, so copper version will consist from 2 parts like here:
Cu+brass set: $13, ~90gr bare weight
Dammit, missed the S11 spacers. Oh well.
I’m in for two S11 spacers!
Some test fitting while I wait on LEDs
C8TT with ANNA mod. Shaping up to be one of my favorites!
Finished product:
Solid copper spacer, 6x Luxeon MZ 5700K.
Wow how many amps on DD FET? Gotta be 35A with a good battery
VaKo you just came to make the n00by move. Please fix your previous post. Posting big images without specifying the relative width parameter breaks the forum page layout for all devices whose screen width is lower than the image's. Use 100 (%) maximum please.
My apologies, used to forum software doing that automatically and I have an ultrawide.
Have made several triple pills:
S11 sets will be ready next week.
These are for S2+?
What is price and weight?
Not seeing these listed in the OP.
Thanks
Yes.
PMed details.
need 3x singles, pmed you
Hi kiriba-ru, I would like an M2 aluminum set please. Thanks
2pcs available for sale.
As mentioned before, this design was not my first choice, but now it looks like most user-frienly quad mod. I never liked soldering driver wires to pcb when it sits down inside deep (yes sometimes 6mm is too deep) pocket, when you are not able to put solder tip at the angle youd like to. With this design there are no such problems, you can solder spacer to brass pill and pcb to the spacer (and even leds to the pcb) within one heating cycle, put driver and solder wires, slide outer brass ring over spacer when all soldering is done and screw whole assembly inside head.
Kiriba-ru, I was hoping to get three of the copper p60 quad drop-ins here at the end of the month. I see there is only one left now. Any plans to make more?
I have few more rejected. PM if interested.
Any parts for Fw3a? Looking for everything that goes into the head and upgrading from stock :slight_smile:
A triple spacer for the FW1A might be more interesting.
