Hi, HKJ - I was wondering if you might review the new XTAR PB2S powerbank with replaceable 18650 / 21700 cells?
14.15€ 8% OFF|Diymore USB Power Liefern CV CC DC 15W Step UP Boost Converter...
Smarter Shopping, Better Living! Aliexpress.com
I got it from Xtar and the review is nearly finished,
Thank you
Yesssss… Yeahhh… Thanks
did you read our post ? we will publish the new power supply , hope you like that , but now we did not sell to the world, we just test it at our country first, if there is no problem, I will publish it formally
Came by around here because I just found an interesting, inexpensive single long slot li-ion/Ni-MH/Ni-Cd charger (supports 2×700 cells), with up to 2A rate (for li-ion at least).
(Edited because of slip-up) Some sales:
Wed, 08/28/2019
Came by around here because I just found an interesting, inexpensive single long slot li-ion/Ni-MH/Ni-Cd charger (supports 2x700 cells), with up to 2A rate (for li-ion at least).
I have ordered one, with the cheapest possible shipping (free).
I wonder why it is posted in my review thread, if RD want me to review it they can just ship one to me (Preferable with box and power supply).
I do like the frontpanel with both encoder and numeric buttons, this is the same as all my professional bench supplies and it usually makes it very easy to use.
there’s a dedicated thread for charger review requests from and for HKJ:
Review request for HKJ [Chargers] | BudgetLightForum.com
Thanks for pinpointing angerdan. The charger is USB powered anyway, so not entirely off-topic LoL. :-))
I just read this post and tell you this , for now we did not publish now
Hi. Newbie here—I just signed up. I’ve been a fan of HKJ’s website since finding out about it two years ago and it is because of his reviews that I purchased a couple of SKYRC MC3000 and an Xtar Dragon VP4 Plus chargers. I sent an email to his website asking for advice and he was nice enough to reply and give me a recommendation. Recently, I got into USB meters and purchased a Power-Z KM001C also because of his review of it. I also purchased a Power-Z FL001Super and a KT001 and I’m thinking of getting a MF001 or a WITRN X-MFI w/ bluetooth. Which do you guys think I should get?
I’m also surprised to find RD tech active here. My first ever USB meter was an entry level RD tech brand but back then I only used it to check if I had a fast charger or not. Now, I use USB meters to check for noise in chargers because I want to protect my devices. Is there an RD tech product with ‘oscilloscope’ feature that can graph and record electrical noise?
Thanks!
15W Adjustable DC-DC CC CV USB 5V to 3.3V 9V 12V 24V 30V Step Up/Down Power Supply Boost Buck Converter Module with Shell Case
4.54€ 11% OFF|15W Einstellbare DC DC CC CV USB 5V zu 3,3 V 9V 12V 24V 30V schritt nach Oben/Unten Power Versorgung Boost Buck Converter Modul mit Shell Fall|Integrierte Schaltkreise| - AliExpress
3.76€ 8% OFF|15W Einstellbare DC DC CC CV USB 5V zu 3,3 V 9V 12V 24V 30V schritt nach Oben/Unten Power Versorgung Boost Buck Converter Modul|Integrierte Schaltkreise| - AliExpress
“This is a DC adjustable constant voltage constant current step up/down power supply module with LED digital tube display. Display output voltage, output current and output power. Adjustable output voltage and current. Set output current to meet the require. It can be used as ordinary buck power supply module, charger and LED constant current driver.”
These 2 models seem to be updated versions of the above, with USB-C port support and also QuickCharge 2/3 trigger…
https://www.aliexpress.com/item/33040278643.html
(same item from another store)
https://www.aliexpress.com/item/33050667129.html
The UD18 tester looks interesting… I’ve always wanted a quick way to check DC5.5 power consumption. Maybe this tester will help. I wonder what’s the upper current test limit for DC5.5 on this tester? I don’t seem to see the specs from the product page. Although the sample pictures on the product page show it testing laptop charging at 20v 3A for 60-watts power consumption, and another picture showing 30v @ 3 Amps for 90 watts (connected to a load tester device)
I’m looking for a good USB Power supply / charger that supports QC 4.0 / PD 3.0 / 45w to 60w.
I.e. Baseus Speed Series 45w / 60w model
Or you test a similar PS that can be bought on BG / GB / FT or AE? Thank you!
Use my list to check: Index of tested and reviewed USB power supplies/chargers
AlsterPlus USB C 100W Powerbank 27000mAh PD 3.0 HUB Ladegerät - BUB160 Externer Akku mit 100W PD Ladeadapter / 100W USB-C Kabel
https://www.amazon.de/AlsterPlus-100W-Powerbank-27000mAh-Ladegerät/dp/B07VQHQQKF/
Diese Website steht zum Verkauf! alsterplus.de ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf alsterplus.de alles. Wir hoffen, dass Sie hier das Gesuchte finden!
https://www.kickstarter.com/projects/1203085035/alsterplus-worlds-most-powerful-usb-c-battery-pack
27000mAh battery with 2x 100W USB-C + 2x 18W USB-A + USB-C HUB, with Pass-Through Charging and more. | Check out 'AlsterPlus: The Most Powerful USB-C PowerBank&HUB' on Indiegogo.
@HKJ : base on your test result, I almost purchased 8 USB chargers for my family, friend and myself, I love the way you did but I also gave you a comment about the difficult in searching your device tested. Would you mind to add the search functionality to let people can search by device name / brand name (full or a part), model…etc ? it will be more convenience for all of us.
THanks
Hello! Recently found an intriguing DIY device in AliExpress, it is an adjustable CC/CV DC/DC boost converter with very low input voltage (2 - 24V), high input current, input overcurrent protection via fuse and resistor adjustable input undervoltage protection. It even features USB output (!) and to top it off its :-)) cheap:
