Thanks guys for your efforts, much appreciated. It should work like this, I’m expecting also LEDs from azhu who sent it already this way to me. Anyway, I take the risk if lost in transit.
The 3500K LEDs arrived and I picked 3 from the middle, I put them in a brand new FW3A for a more real world test:
I’m comparing it to a SST-20 FW3A with a UCL lens (so best case no green AR coating skew). I chose this because a lot of people should have this light and many comments say it’s generally a good LED.
This actually surprised me a little. I didn’t expect the LH351D to get so low in DUV with the higher amps. I only tested up to 1.5A in my previous test so did not know for sure. In summary, it’s slightly above Duv with the 7135’s and gets even more “rosy” looking than the SST-20 on turbo. Of course the LH351D is 300-400K CCT warmer.
Will test this later tonight and get back to you. I also ordered a few of Digi-Key’s 5000K 90CRI (dog farts) since all mine were from Arrow it turned out. I have those to test as well.
It’s actually kind of hard to measure cause these things step down before it even settles down. Also the SST-20 has UCL lens vs the Lumintop optic so add/subtract a few more percent there
Thanks for the output numbers, the difference is not enormous when regulated at the same current. But I like that 3500K so I’m sure that the leds that I will get from you will end up somewhere nice
Just curious has anyone tested how shaving affects the amount of blue light output? I’m guessing since you are only cutting off the transparent silicone and not really removing the phosphor, the amount of blue light emitted shouldn’t change much but just wonder if anyone knows.
The domed shape of silicone is essential for the function, makes sure that as many as possible photons hit the surface close to perpendicular to it, so that internal reflection is minimised and thus photon extraction maximised.
When the dome is shaved off, the surface is flat and much more internal reflection occurs, photon extraction decreases, and also more photons have an extra chance of hitting the phosfor. Especially the blue photons are absorbed by the phosfor and converted to photons of longer wavelength.
The result is that overall a bit less light exits the led, a reduction of the blue peak and increase of green and red.
I installed the LH351D 3500k this past weekend in one of the FW3A’s I have and I must say this is a really nice led. Even with a narrow optic, the beam is a little wide. It adds a wonderful warm glow to everything and really is nice in the outdoors.
