ok. I will consider, but you can see each article is different, I don’t just introduce the product, actually it only takes a small part, I use them to test other charger/power bank/ cable, I teach the methods to other people how to test the quality of their device, the method is useful even if you don’t use our products.
it is a still buck power supply, and it can provide 60V/6A output, and the display part is about (16.5*8*3.5)cm. the case (31*17.2*8.7)cm,the size may be adjusted so it is only a referance. the price is not settled, they need final test to make sure the qualtity can be promised, when the price comes out, I will let you know
If in the future you want to let us know about new products and offers, please make update posts in the samefew threads. For example, you could create one thread called "CompanyXYZ.com New Flashlight Products" and another called "CompanyXYZ.com Current Offers and Coupons".
Affiliate links to your products by your customers should only be placed in the BLF User Negotiated Deals category.
If you want to do a completely free giveaway, please post in the Giveaways and Contest category.
Please introduce your company and clearly state that you are a commercial seller.
Please be polite, respectful, honest and forthcoming.
IF YOU ARE A COMMERCIAL SELLER:
Please DO NOT make commercial posts in any other forum categories except the Commercial Sellers' Spot.
Please DO NOT make commercial posts in the Want to Sell or Group Buys categories.
Please DO NOT abuse your privilege by making many different threads in the Commercial Sellers' Spot.
Please DO NOT make commercial posts about products that are not related to flashlights or flashlight accesories.
Please DO NOT post about your company in other threads unless users specifically request information from you.
Please DO NOT pretend to be a happy customer of your own store.
Please DO NOT ask questions about your own products.
Please DO NOT create many different user accounts.
Please DO NOT send advertisements via the BLF private message system.
Please DO NOT create contests or giveaways that require posting links to your website.
Please DO NOT create contests or giveaways that require purchasing something to participate.
this is the first one of new series, like DPS5005—DPS5015—DPS5020, if customers like this kind of power supply, higher voltage/current version will be published
S06A: 28.43 (normal price 33 USD), S06D: 18.81 (normal price 23 USD), Time is limit, please seize this chance.
here are some introduction pictures, if you want to know more information about RD6006, I suggest you to check the product page, I write everything there, welcome to ask me if you have any questions.
Questions… so this unit is rated for 360 watts, but lists a max amps output of 6 amps. 360 watts = 6 amps @ 60 Vdc. So, can the unit be set for 4Vdc and 15 amps or is 6 amps a hard limit at any voltage? If that is the case, it is not large enough for LED testing. It would be nice to see the input at 48-60Vdc and the output at 15 to 20 amps.
I would definitely use the wireless PC control, that would be super handy as I always have a laptop on the bench or an android device. Power supply could be located under the bench, out of sight, out of mind.
That is exactly what I was afraid of. I guess I will wait to see if this gets upgraded current limits, the comms software looks so much better on this unit. 6 amps is fairly restrictive when testing a DD driver and led combo, or god forbid a decently driven quad or XHP.
I have been eyeing the 5020, but the software makes me cringe!
Hi friend
thank you for your message and your question
for current , the limit current is 6a, even you lower voltage to 1V, the max current is 6a
for now it is only 60v/6a, you can wait some months for higher power supply
