1.25 is best case scenario if the batteries are perfectly balanced, if not you could have one drop below that while the other is running fine at 3.6v for example. In series you’ll need to keep an eye on both batteries separately.
As you have the space and obv the modding skills you could maybe add a couple of protection circuits for an easier life.
Nice mod though! I’m a big fan of sleepers.
Yes, it was originally made for CUTE optics but he is also modifying them and adding a spacer for ANNA optics if you prefer. He also “foybezeled” for me for a small fee since I don’t have a suitable grinder.
My HDS clicky. Reflector bored out, heatsink thermal epoxied in. Triple Nichia 219b sw40. Dr Jones h17f driver. Reverse clicky in place of the original e-switch. Thinking about potting the driver with thermal pad and epoxy for an extra sense of completeness. This is definitely my favorite mod so far
Also finished in the past couple days: Novatac quad sst-20 3500k, 20mm LD-A4 6 amp driver, new glass lens, spring bypassed, etc. Packed full with thermal pad supposedly 12 W/.
18350 s2+ 219b sw45k h17f. Ano stripped and polished because I hate the color but no pics of that yet
I finally got around to replacing the XP-L2 emitters I had put in my Dad’s Q8. It now has an LED4Power conversion board and 4 3V XHP-50.2’s. With aging 30Q’s charged up it showed 12,100 lumens out the front. I have spring bypasses done, and the tail PCB is screwed down with brass screws. While doing the emitter swap I also replaced the factory MOSFET with an Vishay-Dale SIR404DP. Pretty sure newer cells, or hotter cells, would get me up over 14,000 lumens, but hey, at some point I’ve gotta quit buying stuff!
I've been using last years BLF contest winning light a lot more recently and did some more tweaking to it..
I made a new triform lighted momentary tail switch cover, dual o-rings/ copper body section and added a seventh moonlight mode for seven modes in rotary tail action and direct drive momentary tail switch.
Copper, Titanium & Carbon Fibre construction Cree XP-L HI v2 3A 5000K emitter GITD O-ring & LED surround 20mm Copper DTP MCPCB 19mm x 8mm solid copper heatsink 20mm x 12mm SMO Reflector 22mm x 2mm dual coated ARC glass Lighted rotary seven mode tail switch & momentary button Dual colour Tritium indicators Lockout-able Magnetic cell contacts 18350 cell compatible Removable USB charging unit
I guess this is half success and half fail. Got a new bezel for this light and figured I might as well change up some things…
E07 Ti+Cu LED swap
LH351D 3500K x3, 5000K x4 sliced
Added in some red aux LEDs
Failed to flash driver with pogo pins, could never get it to test OK even though I had aux board desoldered
Too scared to push driver out so I didn’t get to flash it like I wanted
Tint is nice already and according to SKV89 changing to UCL lens gets you 0.0020 Duv less which I haven’t done (yet)
Turbo: 5,320lm @ 3s
Anyone know why the phosphor is discolored a bit on 2 of those 3 warmer LEDs? I ran turbo several times and it doesn’t appear to be getting any worse. Whatever it is it can’t be good.
Stepped ramp measurements:
Ambient = 25.6 Lux, CCT = 3812K (Duv –0.0002)
Color Rendering Index (Ra) = 94.3 [ R9 = 69.7 ]
Ambient = 165.1 Lux, CCT = 3875K (Duv –0.0000)
Color Rendering Index (Ra) = 94.3 [ R9 = 70.5 ]
Ambient = 570.7 Lux, CCT = 3893K (Duv 0.0000)
Color Rendering Index (Ra) = 94.3 [ R9 = 70.4 ]
Ambient = 1447.6 Lux, CCT = 3892K (Duv 0.0000)
Color Rendering Index (Ra) = 94.2 [ R9 = 70.2 ]
Ambient = 3083.4 Lux, CCT = 3900K (Duv –0.0000)
Ambient = 5462.6 Lux, CCT = 3971K (Duv 0.0006)
Color Rendering Index (Ra) = 93.3 [ R9 = 67.0 ]
Ambient = 13028.6 Lux, CCT = 4073K (Duv 0.0012)
Color Rendering Index (Ra) = 92.2 [ R9 = 63.0 ]
Ambient = 43541.7 Lux, CCT = 4146K (Duv –0.0001)
Color Rendering Index (Ra) = 91.6 [ R9 = 59.2 ]
The two loops on the head strap of the Sofirn SP40 are too tight and in addition too far away from each other for the short 18350 battery tube. So I fixed it with a knife and double sided velcro straps:
You were right Dale. Opened it up and you could see a slight cut on the dome. I tried to re-do it and even made the optic legs a bit tighter fit with kapton tape and it didn’t matter. One looks just the same and the other looks slightly better now. Going to have to stay like that
I haven’t tried with silicone, but I’ve had many successes in using a small hole drilled at the ends of a crack or split to prevent it from spreading in plastic materials. Something like this:
o———o
Next time, drill a small hole at each end of your planned cut before slicing.
You could try adding a small hole at each end of your cuts now, but that might be difficult.
If you end up needing a replacement, consider a ZebraLight headband. They are available separately on their site. I have several of their 18650 headbands and haven’t had a failure yet.
I just measured one and it is about 20.5mm diameter without a light inserted.
