WTS/GB: [4000k ARRIVED, Test Report's In] GT-FC40 (a.k.a. XHP70's flattop, 12v 40w sister) 95 CRI, Available in 4000k, 5000k
I wonder if these will be available in different MCPCB sizes.
Interested in 1x 4000K and 1x 5000K. Thanks
Probably not in the near future. They seems to be only have 20mm MCPCB in stock for now.
I would like two pieces of the A4 bin (4000K). Thank you.
A4 bin 3PCS
Also add A4 bin 2pcs to my order
Bumping because I’m surprised this hasn’t taken off a little bit more. :innocent:
12V and no testing is a pretty big barrier to entry. We are watching no worries :slight_smile:
The 3A limit is also a possible issue if it truly can’t handle anymore then that. That could be a real issue with using FET drivers which would make it even harder to use these.
I quoted 3.0-3.5 A from the manufacturer’s spec sheet. I have no idea how much it can take more than that due to the lack of testing equipment. I sent the samples to djozz for this purpose.
In comparison, the 12v version XHP70.2’s are rated at 2.4A as the absolute maximum, yet I saw people overdrive the hell out of it.
These FC-40 can probably survive well above 3.5A (at least for a short period), but I probably don’t want to take responsibility for that claim. :wink:
Anyway, djozz has gotten samples, and I hope he publishes the result soon. Keep an eye on the discussion thread.
I thought it strange that the limit would only be 0.5A more then the rating.
Definitely interested in:
(1) 4000k
(1) 5000k
Clemence had problems placing four E21a’s too close together, some of the photons would go out the side of the emitter and heat up the one beside it. It lead to the whole array overheating and dying.
This led has the advantage of phosphor between the dies but the four in the middle may have a hard time trying to stay cool.
Test:
Please put me down for
2) 4000K
2) 5000K
Thanks for the test Djozz. Very interesting results.
I would be interested in a ~4500k 95CRI version for testing depending what my funds look like at the time.
If 4500k doesn’t happen then I could go either 4000k or 5000k. Both if I have the funds available.
If you could get this LED in 3V I would seriously consider swapping my EDC over to it. Just sad there are no TIR optics for this size LED in 20mm.
They said they can do 6v if there is enough demand, but that usually means thousands of pieces to be ordered. That’s something I don’t want to risk going bankrupt over. Maybe @Djozz could try desoldering one of these and see what’s beneath it and if swapping to 6v MCPCB is possible. I previously sent him two pieces so he can abuse one of them as much as he like. :smiling_imp:
4500k seems unlikely as they usually make A5, A4 and C2 bins in their other product stack.
1pc 4000k
1pc 5000k
Anyone care to guess the throw vs xhp35 hi at the same current?
I’d hazard guess slice&diced XHP70.2 in term of beam profile, but less overall brightness due to “CRI Tax”
