Looking forward to it. My 10th Emisar and an Epic one at that!
I find myself agreeing with you so often on here. Ever since I got my Mini One Ti, I think the USB port in the threads is great. This should be quite the light!
I’m skeptical about SST-20 compatability. If Hank is using the white flat, the focus will be a lot different than for any domed LEDs, at least if people’s C8 mods are anything to go by.
A shame Hank almost certainly can’t use CULNM1 in this…
It’s probably too difficult to procure a good flux bin batch of the CULNM1.
Or find them at all if they are already being phased out.
I think it means that it has Ramping OS without updates and that with the pads you can install Anduril for example.
I mean, they don’t have to by set up with a flap.
A flap is easier to design, but they could just be sealed instead (like what phones do). It just means you can’t plug it in until it dries.
Exactly.
It can definitely be tricky to make a single program work consistently on a variety of different hardware. It involves all sorts of different abstraction layers and modular designs to allow the front end to remain pretty much the same regardless of what back end it’s running on.
Which is why FSM is such an amazing beast.
Hank said the head is 70mm which means it should be over 600kcd
Edit: It’s 550+
Edit: It’s 600+ now so I guess I was right
Any news on when it will be released?
Soon™
Interested.
Interested.
Interested!
Sign me up for 1 :-p
(interested)
Hank if you see this thread we would love an update on this project
Yes, we are still working on it, here is the prototype photo, it’s not called D1SV2, it’s called Noctigon K1,
with fully regulated driver, it should reach 600+kcd with CSLNM1.TG LED, there will be green/red
beam version, as well as XP-L HI/HD LED with different color temperature.
Beautiful!
This looks like it will be a killer light!
What battery does it take?
