WTS/GB: NICHIA 219B NVSL219BT-V1 R9080 EMITTERS! sw45k, sw40, sw35, sw30
356 posts / 0 new
mattlward
mattlward's picture
Last seen: 2 days 9 hours ago
Well, since the 219C fell through, put me down for 6 of the 219b sw35 r9080’s.
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
azhu
azhu's picture
Last seen: 3 hours 3 min ago
UPDATE: sw30 and sw35 r9080 will arrive on 9/3.
Need Nichia 219b r9080 Emitters? (。◕‿◕。)
“The Light shines in the darkness, and the darkness did not comprehend it.” John 1:5
KevinZA1988
KevinZA1988's picture
Last seen: 20 hours 7 min ago
By the way, I flowed SW40’s in my FW3A and SW45K’s in my FW3C. Carclo 10511 optics.
SW40 – not a hint of green, pure white tint, gorgeous color rendering.
SW45K – beautiful white tint with that magenta rosiness, gorgeous color rendering.
On turbo, both go more rosy, but nothing like the big tint shift with SST-20’s. I prefer these even if they have less throw. Not even white wall hunting can fault these emitters in my setups. Thanks Azhu! Looking forward to the next batch!
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
mattlward
mattlward's picture
Could not agree more, I have SW40’s in one of my FW3A’s and SST-20 FD2’s in my other pair at the moment. The FD2’s are pretty darn good as well.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
azhu
azhu's picture
Could you post beam shots of the sw40 next to the sst-20? I’m curious to see the difference.
mattlward
mattlward's picture
I will, I had them all taken but my memory card seems to have crapped out. I do still like the sw-40 better, but really only for wall hunting. The FD2’s are really good. There is the smallest hint of off color at very low to moderately low drive current. At mid to high current they are just super!
I will shoot the set again this weekend if I can’t recover the images. The most telling is when comparing the D4V2 SST-20 to the FW3A SST-20 FD2. I will shoot with a fixed daylight white balance and with a close white balance of 4000k.
I may also build one with SW-45k’s this weekend to add to the comparison.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
calipsoii
Last seen: 4 days 1 hour ago
Please put me down for:
10x sw35
10x sw40
With shipping to Canada.
Thanks!
azhu
azhu's picture
LABOR DAY SALE! Nichia sw40 are only $3/ea! Ends Monday 9/2.
Joshk
Joshk's picture
Last seen: 4 hours 23 min ago
Nooooo! The dreaded sale-on-something-I-just-bought!
I’ll be ok, I’ll be ok.
Good luck.
azhu
azhu's picture
Good luck.
Haha don’t you just hate that? Good news though, you can buy more so you don’t feel left out! Silly
Joshk
Joshk's picture
Big Smile
trailhunter
Last seen: 1 week 2 days ago
Does sw45 and sw45k have the same CRI?
jon_slider
jon_slider's picture
Last seen: 8 hours 36 min ago
I dont know the full technical answer to your question, but imho, the sw45 and sw45k are essentially identical in CRI and only differ in tint, the K being more pink
here is info with charts by maukka on various LEDs that you may find helpful also
https://www.virence.com/product-page/nvsl219bt-v1
http://budgetlightforum.com/comment/1096106#comment-1096106
staticx57
Last seen: 9 hours 43 min ago
Since the SW45 has a better chance of being on the BBL I would suspect on average it would have a higher CRI.
trailhunter
I thought sw45k had a guaranteed chance?
azhu
azhu's picture
The ‘k’ designation only implies that it is below BBL.
jon_slider
the sw45k is guaranteed to be below the BBL.. that info is Tint, it is not the same as CRI, which is a separate variable.
the fact that the sw45 tends to not be as far below the BBL is the reason the sw45 is yellower than the sw45k, or to put it another way, the sw45 is less pink, but that in no way means it has more CRI.. again, the BBL relationship only tells you Tint, it says nothing about CRI
so, If you want high CRI w more pink tint, further below the bbl, then SW45k is the winner
if you want the same high CRI with less pink (more yellow) tint, sw45 is good enough
since some people object to the extra pink of the sw45k
I offered only sw45 when I had a batch of lights modded for resale
otoh, the one I use for myself, is sw45k, because I dislike the yellower sw45, by comparison
all things are relative, Im totally fine with sw45 if I cant get sw45k
besides, you cant get sw45k from andy anyway, I bought the last ones… LOL
here is an excellent example of the difference in tint of the sw45 and sw45k
you can see that the sw45 has more “neutral Tint”, not to be confused with “neutral white color temperature”
both the sw45 and the sw45k look pink on my white kitchen ceiling during the day, when my brain is adapted to sunlight (5700k)
both the sw45 and sw45k look white at night, when my brain is white balanced to 3000k incandescent
the sw45 is a great LED, for me, the sw45k is greater ;-), but either one is better than any sw40, during the day, when daylight white balance is influencing my brain’s color perception
staticx57
Why do you think tint is a seperate variable? CRI is a measurement of a light source against an ideal black body. Tint is shifting away from an ideal black body. IE a 100 CRI light source would have a DUV of 0
jon_slider
because in a post I cant find yet, maukka educated me that there are low cri lights that have tint on the BBL
as a rough example, consider an LH351d whose tint is closer to the BBL than an sw45k, yet the sw45k has higher R9 CRI
tint happens to both low CRI and High CRI.. my understanding so far, is that how close tint is to the bbl is not linked to how high the CRI may be.. im open to a better understanding if Im mistaken
Ive been wrong before, when I though I might be mistaken.. lol
clemence
clemence's picture
Last seen: 6 hours 12 min ago
CCT, Y axis, affects how the CRI computed. Lower than 5000K (to the right from at Y axis) use black body radiator as reference. And higher than 5000K use D50 or D65 as reference.
Duv (tint), X axis, affect the tint (yellow, blue, magenta or green) within the same CCT.
There’s certain threshold where duv or tint is considered acceptable. Above or below 0,005 (forget what is the correct standard) is usually considered to be non standard or special color bin. AFAIK, Maukka mentioned about this somewhere. That light source’s CRI with duv too far off the BBL can’t be calculated. Or becomes meaningless.
Nichia has several duv bins for these non standard tint. Sw45k, and Rs30 for example.
Nichia also don’t mention CRI value for Rs30 and the likes.
[Clemence]
contactcr
Last seen: 51 min ago
All else being equal proximity to BBL matters but in reality the spectrum will be different too.
Tally-ho
Tally-ho's picture
To illustrate this :
(Source)
azhu
azhu's picture
UPDATE: sw30 and sw35 are arriving today. All those that expressed interest have been PMed.
id30209
id30209's picture
Last seen: 49 min 11 sec ago
PP sent!
WTB  Jetbeam TCR1  &  Titanium 47 2xAA Quark
azhu
azhu's picture
UPDATE: I have 35 pcs of sw45k available. First come first served.
808Hi
Last seen: 1 day 16 hours ago
I’ll take 10pcs sw45k
candor
Last seen: 6 days 23 hours ago
I’d like 6 sw45k.
likevvii
Last seen: 1 hour 10 min ago
I want to purchase 6pcs sw45k please
gcxmr2
Last seen: 2 weeks 20 hours ago
I’ll take the rest of the sw45k. (13 pcs?)
azhu
azhu's picture
UPDATE: Out of sw45k. Will try to get more in the future.
