Just received the 219C purple version from Illumn. The finish is so beautiful. Perfect gift for the ladies! Here are some measurements:
At turbo using P26A cells with stock carclo and lens:
lumens: 2,180
CCT: 4105K
DUV: 0.0029
CRI: 91.0
R9: 56.4
Rf: 88
Rg: 96
At low output using P26A cells with stock carclo and lens:
lumens: 53
CCT: 3994K
DUV: 0.0033
CRI: 92.9
R9: 68.3
Rf: 88
Rg: 97
It is noticeably more green that the SST-20 4000K version at all levels. With just a slight bit of extra output, I don’t see any reason in buying the 219C version instead of the SST-20. I bought this just for testing since no one posted any test results on the 219C version thus far. Will not get any more 219C version lights unless the manufacturer can source the rosy 4070e bin 219Cs.
TY. It’s all etched with a tiny bit of 800-1200 grit wet/dry work and a little polishing. If you do it in several layers you can create more depth and shadowing in the look of the design than there is.
Ferric Chloride! TY! The clip is softer steel so it will etch quicker. I sealed the button off (underside) on some electrical tape and sealed the edge with fingernail polish so the tolerances for fit/use weren’t etched at all. I also left the bend and hole of the clip out of the FC other than a quick dip for color.
Not much of a Mod—- I changed out the XPL-1A to Samsung 4k —- Very nice tint now — Surprising the Lumintop Optic works well with these LEDs— Seems to be more Floody with less artifacts — I have the same LEDs in a S2+ with the 511 optic to compare
I also had to get rid of that shiny clip from the Vipon buy light — I bead blasted the Clip and Button (better) — I’m thinking about Blueing the clip but the button is aluminum so that’s a no go—- I like the Heated look also
[quote=chops728]
The button is stainless steel and can be colored with heat….so can the clip…
question… I just got a fw3a from amazon, but it came with the plastic optic and no glass lens. I have some carclo optics, but I dont have the glass lenses… anyone know where we can get them? (23mm x 1.5mm ?)
