TY. It’s all etched with a tiny bit of 800-1200 grit wet/dry work and a little polishing. If you do it in several layers you can create more depth and shadowing in the look of the design than there is.
Ferric Chloride! TY! The clip is softer steel so it will etch quicker. I sealed the button off (underside) on some electrical tape and sealed the edge with fingernail polish so the tolerances for fit/use weren’t etched at all. I also left the bend and hole of the clip out of the FC other than a quick dip for color.
Not much of a Mod—- I changed out the XPL-1A to Samsung 4k —- Very nice tint now — Surprising the Lumintop Optic works well with these LEDs— Seems to be more Floody with less artifacts — I have the same LEDs in a S2+ with the 511 optic to compare
I also had to get rid of that shiny clip from the Vipon buy light — I bead blasted the Clip and Button (better) — I’m thinking about Blueing the clip but the button is aluminum so that’s a no go—- I like the Heated look also
[quote=chops728]
The button is stainless steel and can be colored with heat….so can the clip…
question… I just got a fw3a from amazon, but it came with the plastic optic and no glass lens. I have some carclo optics, but I dont have the glass lenses… anyone know where we can get them? (23mm x 1.5mm ?)
