does it matter?
they are all too hot to charge the battery (all are over 113F), so dont leave a liIon on charge in the vehicle, on a hot day
the hottest spot is also above the max operating temp for a LiIon (140F), so dont try to use that light until it cools doewn, or it may have “venting with fire”
otoh, if you neither charge, nor use the lights, at the temperatures stored in a car
then
it makes no difference where in the car the light is…
I hate guessing, so, when youre ready, just tell me Im right… cause I already know where the hottest spot is, and I aint tellin… lol
I’m going to say under the seat is the hottest due to the heat coming off the asphalt. My initial thought was that the glovebox would be the hottest place since the sun would be beating down on the dash but I’ve never noticed my glovebox being hot when I reach in it.
1. Glove box the coolest
2. Under the seat
3. Center console the hottest
Of course the coolest spot in my Blazer is in the rear in the ice chest. Also another major variable is if your windows are tinted and how dark they are. Even with my fishbowl the rear being tinted 20% you can tell it’s cooler than the front seats with 35% on the doors. I use a windshield shade if I have to park long term in the sun. My interior is saddle (tan) so it will be cooler than a grey or black most modern cars come with.
Anybody who’s ever worked on a sunroof is familiar with how hot the roof of a vehicle can get. A few square feet of sheet metal acts as a nice collector and heat sink in direct sunlight.
It’s tough on thin layer of foam between the headliner fabric and the backing board, and the adhesives that hold the sandwich together. Drooping headliners are not uncommon, even though they’re serve no duty other than as decoration, and receive no direct contact or wear. Refinishing them requires an adhesive that is both strong and heat resistant.
Modern vehicle designs with steeply raked windshields result in more dashboard surface area, and more exposure to sunlight, and a dark-colored dash, as they often are, adds to that. So the glovebox, sitting below that nice heat collector, is my guess as the hottest of the candidates.
Between the center console, and under the driver’s seat, the latter sees the least exposure, and is unenclosed, so it will be the cooler of the two. The floor contains most of the sound insulation material in a car, and between it and the carpeting, is well insulated from ground heat, as well as that generated by components like the catalytic converter and the exhaust system.
I have lights in the door (Pro Seeker2, FW3A 7a), center console (FW3A 1a), ashtray (S1R Baton I, Prometheus Beta), and in the back with my tools (Noctigon Meteor 219c, Olight H1R & H2R, a Black Diamond Storm). South Florida is brutal in the summer so I’m sure I shouldn’t be keeping all this LiIons in my truck but I like to be prepared for anything.
I hear ’ya Watermancris, there’re other lights in the car, but only a thrower and a floody in the glovebox. There’s also a lighter plug-in corded handheld light (no batteries) and both a headlamp and a stand-up work light but they’re in trunk for emergencies, didn’t mention the trunk lights as it wasn’t part of the Poll
The center console was the hottest,
The dash glovebox in the middle,
And under the seat was the coolest.
I was leaning toward the dash being the hottest place till I saw the data.
On this car there is the airbag and AC ductwork between the glovebox and the hot dash or engine compartment. I’ll bet there is 10 to 12 inches of stuff between the box and the top of the dash.
The center compartment only has a thinly padded top. The sides are a single layer of plastic.
140+ degrees is darned warm. That’s warmer than tool makers say to use. A naked powertool sitting in the sun can certainly be hotter than that.
Yet there must be tens of thousands of cordless power tools baking away on jobsites across the country and I don’t really recall any stories of fires. Still, those batteries are not in bomb tubes (err flashlights).
