I’m still waiting for my strap wrenches to open the fatty.
Did anybody measure the glass diameter, thickness?
It seems mine is not AR coated so I’d buy another glass.
Thanks for waring me.
Does it have anything in common with the color of reflections you can see on the glass surface? Sometimes the coating is green, sometimes violet, pink, blue…
Would you recommend any alternative?
I don’t see even a hint of AR coating, which is fine with me.
Yeah, it discolors the beam, generally greenifies it and makes it yicky.
If you’ve got an Angry Blue™ light anyway, the extra green just makes it more aqua or whatever. Might not even be that bad. True neutral white would probably show it up more, definitely green-hued vs, well, neutral. Warm white would tend towards pus-yellow instead of rosy.
I ordered the Wurkkos W30 and it just arrived today.
I’m testing it out. Noticed some things. The UV isn’t 365nm (already mentioned above). I notice that it will not make certain ‘markings’ on our country’s currency glow, unlike when I use the Convoy S2+ with Nichia UV365 or Convoy S2 with LG UV365 LEDs.
Another thing is, I’m not sure if this has been pointed out in the earlier pages — it might be a bug:
this occurs after going the alternating white+red strobe mode of the red light mode; what I think s a “bug” is that both the red and white LED will be lit up at the same time after following the sequence below)
1) from Off, double-click to operate Red light
2) double-click again to operate Strobes mode of Red light (flashing Red only)
3) single-click to advance to next strobe mode (alternate flashing Red + White)
4) now when the light is actually flashing the White LED, do a double-click
(what this does is go back to the regular Red light mode)
=> the bug is that, now in regular Red light mode, use single-click to advance to next higher Red brightness level;
when the Red is on High mode, the white LED will also be lit up (in Low brightness).
Normally, when in regular Red mode, single-click will advance the Red light brightness, but will not turn on the White LED.
But following the above sequence, it appears to trigger the Red + White LED being turned on at the same time
(the White LED becoming On while in Red light doesn’t seem to occur all the time, but it seems to get triggered more often when doing the ‘double-click’ while the flashlight is in Alternating Red+White and the light is actually flashing White at the time of the Double-click).
It doesn’t always occur, but doing it a few times will trigger the white LED also lighting up with the Red LED (on High).
The trigger is: while the flashlight is in the “alternating Red + White strobe modes”, do a double-click while it is flashing white LED. This will go back to regular Red mode, but cycling the Red to High will also light up the White LED.
Mentioned above is “resistance leak”, just wondering is this easily fixable?
