Thanks very much, sure was a lot of patience went into this one
Diffuser/ protective case.
I made a simple diffuser from an old berocca tube.
Rubbed down with wire wool to remove the printscreen, cut some from the length of the tube, installed a ring of stickyback felt inside the tube for a snug fit and added some GITD powder & UV glue to the ends.
Can also be used as a protective case for the light.
Copper & Titanium construction Cree XP-L HD v6 3D emitter GITD O-ring & LED surround 20mm Copper DTP MCPCB 19mm x 8mm solid copper heatsink 20mm x 12mm SMO Reflector 22mm x 2mm dual coated ARC glass Lighted Rotary six mode tail switch & Momentary button Dual colour Tritium indicators Lockout-able Diffuser/ protective carry case Magnetic cell contacts 18350 cell compatible Removable USB charging unit
Length – 94mm Width – 25mm Weight – 180g(With 18350 cell) Parts Made - 80 (Approx) Time to build - 101 hours
Modes, Operation & Light output:
Pressing the momentary button or turning the rotary tail switch clockwise gives these approximate outputs:
The rotary tail switch can be operated through 360° in either direction starting in the highest or lowest mode. The use of a lubricated o-ring underneath gives just enough friction for smooth operation. The tail push button gives momentary access to the highest mode. The tritium markers give an indication as to switch position/ charging mode.
When the two green tritium vials are lined up on the outer shell , the light is in the off position. When the green indicator on the rotary tail section is turned to line up with the red indicator in the body section , the light is in direct drive mode, or in charging mode if the head section is then disconnected and the USB charger port is exposed.
Other than that the tritium indicators let me know where the switch is positioned.
I modified the CRX Rotary with a 3K carbon fibre jacket, swapped the XP-L HD 3D emitter for an XP-L HI 3A 5000K, re-made a new momentary tail switch cover, dual o-rings and added a seventh moonlight mode.
Carbon fibre, titanium & copper construction Cree XP-L HI v2 3A 5000K emitter GITD O-ring & LED surround 20mm Copper DTP MCPCB 19mm x 8mm solid copper heatsink 20mm x 12mm SMO reflector 22mm x 2mm dual coated ARC glass Lighted seven mode rotary tail switch & momentary button Dual colour tritium indicators Lockout-able Magnetic cell contacts 18350 cell compatible Removable USB charging unit
I decided to perform some tweaks & tuning, swap the emitter, add a little more copper heatsinking, install all the tritium vials and add an electronic tail switch with ramping firmware driver.
Mokume Gane copper & brass body Cree XP-L HI v2 5000K on copper DTP MCPCB OP reflector ARC glass Brass pill with added copper heatsink MTN 15+1 FET driver with D4 v2 ramping firmware Electronic tail switch Installed ten 6mm x 1.5mm red tritium vials
I also made a protective carbon fibre felt lined holster & spare cell carrier/ charger for the Mokume LAN.
Dyneema wrapped & GITD LED surround.
Runtime graphs using a Windyfire 14500 600mAh cell and a new Vapcell 14500 1000mAh. Two runs of each cell, one starting on maximum output and another starting around 600lm.
- LEDs & Other Stuff - - UI CheatSheets - - CRX Mods & Builds - - Stuff for Sale -
- The Old Lumens Flashlight Modders & Builders Challenge is Now Open - Link -
This light is so marvelous both in appearance and technique!
BLF Q8 Janus --- Emisar D4 RGBW --- Green Lantern and HAL 9000
My 6th Annual Scratch Made Light Contest Entry
CRX Rotary - Complete.
Specifications:
Lockout-able
Length – 94mm
Width – 25mm
Weight – 180g (With 18350 cell)
Mo Switch - 1560 lm
Mode - 1 - 1500 lm
Mode - 2 - 450 lm
Mode - 3 - 180 lm
Mode - 4 - 45 lm
Mode - 5 - 3 lm
Mode - 6 - FF lm
Max cd - 9000
Max Throw - 190m
Operational GIF
Upgrade Edit: 31:08:2019
Lockout-able
Length – 94mm
Width – 27mm
Weight – 192g (with 18350 cell)
New Modes, Operation & Light output:
Momentary Switch - 1300lm
Mode 1 - 0Ω - 1269lm
Mode 2 - 1Ω - 380lm
Mode 3 - 3.3Ω - 162lm
Mode 4 - 15Ω - 44lm
Mode 5 - 180Ω - 15lm
Mode 6 - 820Ω - 4lm
Mode 7 - 1200Ω - ML
Max cd 15000 - 245m
CRX Rotary revised runtime graph in modes 1 & 2.
CRX carbon fibre, titanium & copper triumvirate flashlight set.
beautiful work!
Such a refined and precise bit of craftsmanship there CRX
I take my hat off to you
G'day mate, ow ya garn?
Yeah, nah good mate
I’m starting to believe that you are not human CRX. Is there something your not telling us? Should we be afraid?
djozz quotes, "it came with chinese lettering that is chinese to me".
Thanks chaps
Course not, I like you guys
Soo stay on your good side. Okay got it
Now that you have the protective case you must be ready to send it to me
I agree with Moose, your skills are not normal
Wow! Unbelievably beautiful!
Need to have this one Mass Produced!
KB1428 “Live Life WOT”
Cheers David
Nothing to see here folks, move along...
In less than a month you can make this masterpiece of illumination and we don’t have a FW3A yet. Amazing.
I love it, very classy yet practical. Hard to succeed at both. You are a talented man my friend. Great job. Congrats.
I say congrats because the win I think is in the bag.
"Everywhere I go, there I am"
I am considering making a piston drive light at some point, which may or may not be completed before the FW3A
Once again an impressive light CRX. You keep improving your builds
Piston rod light sounds nice. I have a piston in use as an ashtray, looks nice too. And not so complicated to make
I saw what you’ve done there
BTW, and regarding to you flashlight, I like the “diffuser” option
“Recycling” materials is surely a neat way to improve the work already done
[REVIEWS] AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// ACEBEAM: H20 / TK16 /// BLITZWOLF: BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 / E10 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// KLARUS: XT1C /// LUMINTOP: Tool AA V2.0 + Tool 25 /// LIVARNOLUX: 314791 /// SKILHUNT: M150
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2 /// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
GIVEAWAY: 1
So Berrocas are the secret to your talents.
Just had time to catch up reading through the finished build – Outstanding build, & really well doccumented. Hats off
Do you have anny Beroccas left?
I am astonished, astounded, awestruck, bowled over, etc.
BLF Member Map Add your name and location.
When I see the title of this thread I keep thinking your crx has a bridgeport rx-7 mazda motor
Dc-fix diffuser film >… http://budgetlightforum.com/node/42208
Awesome build as always!!
Holy crap, I love this! Extremely well done!
USA based seller of flashlights, batteries, and chargers.
Illumn Webstore /// Instagram /// BLF DEAL THREAD
Way cool!! I love to go to the large images and zoom in on the detail. Fine stuff you do!!!!
I received my prize from the contest, the Reylight LAN Mokume Gane.
Thanks very much Rey
OP reflector
ARC glass
Length - 96mm
Width - 21mm
Weight - 123g (with 14500 cell)
Max - 1300lm OTF
Max cd - 7700 - (175m throw)
Mokume LAN runtime graph 60°C
Mokume LAN runtime graph 70°C
Good product photography is difficult to do too
Just found this marvel thread…WOW…just WOW David.
How can one buy this Rotary???
WTB Titanium 4sevens Quarks & Jetbeam TCR1
David?
This one can’t be bought, one of my favorites.
- stevi –
[/quote]
David?
- stevi – ;)[/quote]
LOOOOL
Was talking to David previously :)))
This Rotary conceptis what many flashlights need
I’m also a big fan of rotary interfaces…
