@Simon . Looking at the XHP35 driver, can I just confirm that its 2.3A at the output and single cell only (i.e., wonāt work on 2 cells)?
Would it file down enough to fit an L2 (~21mm)?
Two of my lights (L2 and S11) have XHP35 HI and are using the H2-C 22mm 1.5A from KD, so your driver is very interesting.
Yokiamy
(Yokiamy)
August 5, 2019, 8:30pm
133
ecotack:
Yes, that should work, the driver is just released, single cell driver for XHP35.
It should fit, since the L21a (21700 version of the L2) is the first to be introduced with this driver.
https://nl.aliexpress.com/item/4000056253432.html?spm=a2g0z.12010612.8148356.1.755c6d6cylPwhS
Simon_Mao
(Simon Mao)
August 6, 2019, 2:08am
134
it runs on 18650/21700 battery ,
170KCD, 824meters
Simon_Mao
(Simon Mao)
August 6, 2019, 2:09am
136
L21A XHP35 820meters
L21A SST40 720meters
Simon_Mao
(Simon Mao)
August 6, 2019, 2:10am
137
ecotack:
22mm ,it only can be installed in L21A
Boy does THAT sound like a challengeā¦
Just ordered 2. I love a challenge
abgx1
(abgx1)
September 4, 2019, 7:42am
140
Can l2 throw 2000lm all the time?
Can it work on 21700 battery?
Or is there any other convoy flashlight under 50ā¬ which can do this?
Yokiamy
(Yokiamy)
September 4, 2019, 7:34am
141
For 21700 , there is the L21A version with XHP35
I donāt know if it has temperature stepdown, otherwise removing the NTC on the driver will disable it.
abgx1
(abgx1)
September 4, 2019, 8:06am
142
Removing temperature stepdown wont solve the problem, cos then you cant hold it in your hand
So tldr:
2x21700 big flashlight with good cooling and over 2000lumens
Size and weight isnt problem
Simon_Mao
(Simon Mao)
September 4, 2019, 8:44am
143
2400LM,
no adpater for 21700 battery
abgx1
(abgx1)
September 4, 2019, 8:50am
144
So 2x 26650 version can also work on 2x 21700 without adapters?
Is it able to be cold enought to hold even on full 2400lm mode?
If yes I am going to order one right now
DB_Custom
(Dale)
September 14, 2019, 1:25pm
145
abgx1, why 21700? The Golisi 26650 almost matches a 30T and has 50% more capacity.
DB_Custom
(Dale)
September 14, 2019, 1:27pm
146
You will need to make a tube to prevent battery rattle if you go with 21700ās, roll up thin cardboard or somethingā¦
abgx1
(abgx1)
September 27, 2019, 9:46am
147
Its working with 21700 great, its not even rattling, as they are very long, so there is enought pressure from springs that they wont move
LessDark
(LessDark)
September 28, 2019, 11:13am
148
Any plans for releasing a xhp50.2 3v single cell version of this light?
Sari33
(Sari33)
September 28, 2019, 6:19pm
149
I would see also a New L2 with Larger driver bay
abgx1
(abgx1)
October 12, 2019, 9:02pm
150
temperature after running for 30mins on full in room temperature without moving
pennzy
(pennzy)
January 6, 2020, 9:53pm
151
Just a shout out to Simon for good CS. I placed a small order for TIR lenses and asked for a C8 driver retaining ring. He threw in 2 free ones and got the order to me door to door in 2 weeks. Great service.
