If you really need a powerful wide beam UV light, there is always the Acebeam X80 UV. 16x Nichia 276A 365nm UV LEDs!
https://www.batteryjunction.com/acebeam-x80-uv-ultraviolet-search-light.html
See djozz’s post about this issue:
As Henk pointed out, the 276A is a rather sensitive led that does not like getting hot and being overdriven. I’m not sure if Acebeam was aware of that but here on BLF it has been found years ago. What happened to one of my lights in which a 276A was slightly overdriven is that the white stuff in between the traces on the led disappeared and that the led started emitting lots of visible light, with output loss of UV. Healthy led on the left, damaged led on the right. [image] [image]
Okay, so the way I’m looking at it:
5*7135 = 1.75A, so three would be 5.25A. The driver that’s in the light runs 6A at 100%.
R050 and R015 in parallel (replacing the R010) on the driver board would end up at 5.2A. So pretty viable I’d think, but to be conservative, just the R015 to make it 4A, so less heat (distributed over three emitters).
Simon Mao: texas shooter: Simon Mao: texas shooter: Simon Mao: mattlward:I saw a P60 mentioned… I do wish there was an affordable 21700 P60 light out there. I use many of them for sane output lights, granted they do not make great hot rods but I do not always need a hot rod light.
Any chance Simon?
I am not sure if the P60 has a patent for appearance.
Patent issues with the clones was on the dropin pocket size. The solution was that Solarforce and many others increased the pocket dimensions. Now needing that additional spring around the pill. However appearance is up to the creator. Your S12 tail cap and battery tube portion would be a nice style that’s yours. Then a dropin pocket added on top. But please keep the head threads standard for all those custom heads. Personally I would buy at least 10 to upgrade run times on most of my “around the house and car P60’s”. Granted the style and function might be dated, it’s still the one loved by many. It’s the only host I use to build lights for my fellow officers in my area. Mostly 1 to 3.8 amp dropins were heat is not an issue. The flexibility of swapping dropins allows the same light to work patrol, currency verification, organic detection, etc. If a little extra attention is made to the tail cap and double o-rings on the head and body to keep that high level of water proofing, great. I prefer simple always working duty lights without electronic switches or charging ports. It’s always been a P60 from Surefire or Solarforce on my duty belt for the last 15 years. Some newer lights are brighter but none are better.
i’m sorry ,i’m not familiar with P60 ,i have a silly question ,is it 26.5mm drop-in in P60 or suitable for P60?
Not a silly questions if I’m trying to persuade you to build them. The 26.5mm drop-in was specifically built to go into P60 style host. Along with the 17mm driver. Surefire came out with the P3 single cr123a, P6 double cr123a and the P9 triple cr123a all have this same 26.5mm drop-in pocket. About the time they converted to LED’s they became the P30, P60 and the P90. This denotes 3v, 6v, and 9v. Most clones went to the P60 which was also about the time the Li-ion 18650 cell came out and it all lined up as the perfect match. P60 size, LED’s and the 18650 all came together creating this light but Surefire did not convert to 18650 but stayed with 2-cr123a’s for extreme military conditions. Several years latter the P60 clones stayed the same but 20700 and 21700 batteries have been introduced. When the NCR20700A from Panasonic/Sanyo came out we went from 3500 mah/10amp 18650’s to 4200 mah/15amp over night. I hoped that some one would upgrade the host to this huge gain, but no. Now at 21700 cells we have nearly 5000 mah/10amp cells. I could work traffic accidents all night long in the worst weather and not need a battery change.
If you could be persuaded to build the host great.
Would you also consider building a 26.5mm drop-in with your Convoy 17mm driver for SST40 ,4 modes 0.1–3–30–100, 5000mA. As a separate item or packaged with the host as a option.
Thank you,
PaulThank you very much for your explanation. If I design the 21700 version of the P60, I want to make integrated head or brass drop-in for it instead of D26 ,
This structure of D26, I think it is not good for heat dissipationTime for my silly question. What is an integrated head and would it still allow drop-ins to be used?
for example ,the C8
Simon, what’s the diameter and thickness of the glass on the S12?
30.8mm diameter,2.5mm thickness
Fantastic, thanks! Going to turn it into a UV cannon at some stage
Mocarny: Simon Mao: Mocarny:Simon, is it possible to make turbo mode access only after 2 click, from any position(on or off) without memorizing it?
So it could be 0,1% - 1% - 10% - 40% and turbo after 2 clickyes ,and what driver model?
It could be in driver for SST40 and new 3*SST20
If turbo is only 1-2 min I can’t see point of memorizing it, and it would give more modes, 4 in loop and turbo when needed. Then it could be really “turbo”, not the highest mode
I definitely want it for S2+ with SST40 (and all other models too:)
Is there any estimates when it will be available?
Simon, could you please tell if there are any plans for it? I mean turbo access by two clicks (from “turned off” state as well).
I want S21A with sst40 and this feature, if possible.
andr3w: Mocarny: Simon Mao: Mocarny:Simon, is it possible to make turbo mode access only after 2 click, from any position(on or off) without memorizing it?
Is there any estimates when it will be available?Simon, could you please tell if there are any plans for it? I mean turbo access by two clicks (from “turned off” state as well).
As far as I understand, 2 clicks from off state is only possible with e-switch. But from on, instead of strobe it is possible. More low modes in EDC light is always nice
I like the design of the S12, but I still feel a little burned by the battery size issues of the S21a.
The M4U - Yeah - a nice tube style 26650 light.
What driver is in it?
Can it be flashed to something more interesting? (Anduril - I fear I’m becoming a UI snob)
I’m OK with even “click+halfclick” sequence, it should be possible with any switch.
However for stress situations, second full click might be better.
I see the H1 is (back?) on the Ali store. Different knurling. I’m guessing with the updated UI that’s been talked about?
And does it has now the updated headband?
The M4U - Yeah - a nice tube style 26650 light. What driver is in it? Can it be flashed to something more interesting? (Anduril - I fear I’m becoming a UI snob)
I can see in the page description that it's running Biscotti.
Also in one of the pictures you can notice the cut-out in the driver and a mechanical switch going flush with the cut-out.
amishbill:The M4U - Yeah - a nice tube style 26650 light. :
) What driver is in it? Can it be flashed to something more interesting? (AndurilI fear I’m becoming a UI snob)I can see in the page description that it’s running Biscotti.
The bigger issue - I forgot that this has onboard USB charging. The spacing relative to the first cooling fin makes me think it’s built into the driver. Between the two, I doubt any other driver would fit or work. :-/
Headband looks the same in the pics. Will wait for someone to grab it and check UI etc.
Still meh about XML2.
Convoy already release S12 HOST…check it out
The M21B host link should be up soon as well. All it took was four sentences on my part and I didn’t even tell him I’m a member here.
Amazing customer service. Hopefully these sell well enough to make this worth his effort.
My concern is the cost of the host - the host + driver is already more expensive than the full light, so I guess that’s the point? Maybe I’ve got the sales pitch around the wrong way.
Is there any estimates when it will be available?I have done such a driver sample before, I am not sure if there are many people who need it, so I did not mass produce it. (and turbo only from “on” state)
