neal
I have a few spare stock lenses I could send you one…no charge…
Anyone have an extra rubber ring from their FW3A that they don’t plan on using? Looking to pick up an extra one or two. PM me.
So what’s the most popular led for direct replacement on XP-L HI boards , the Samsungs?
LH351Ds, yes.
Thanks!
WTB trit switch that sits flush
A switch thin enough to sit flush would not be thick enough for trits. It is one or the other.
PM address I send switch CRX. I will give you a 5 star review
Ah! Very clever CRX. Using the inside of the button!
Stone wash Ti clip on Brushed Ti/Cu FW3….Polished Ti clip for the mini… kicking around idea’s where/which end to mount and or modify the clip?
Kinda looks like a Bug… wonder if they make colored Ti screws…. Red Eye’s and Red Trit’s in the tail?
Ti Bug Noir…
What clip is that —-Awesome looking
Neal’s Gadget’s HTP WORKS Titanium Clips For Hanko Barrel OKLUMA CWF Boss Reylight Fl – Nealsgadgets
+1 Thanks
I haven’t been edc’ing this much because I’ve had trouble pushing it in my pocket without pushing the button. But today I might have cured that. I’ll see how it goes.
I had a similar idea - I’m looking forward to hearing about your experience with it. How did you attach the extension?
It’s it seems to work. Someone else used a washer attached with e6800. I’ve thought about it, I just haven’t bit the bullet.
The ‘extension’ is something i lathed up. Very similar to the washer pic below. It is just a press fit (finger press). Not glued because I didn’t know if i would like it. Been edc’ing for several days now. No issues at all wtih accidental turn on. The extension has also not slipped off despite only being pressed on finger tight. Definitely a worthy mod IMO.
This is the post, where does the white wire on the negative side go?
