Rey Engine
do it just like anduril
your UI looks like BLF A6
which is good
i;ve always wanted mode spacing like this
1 2 4 8 16 32 64 128 256 512 1024
with a really fast way to switch , like BLF A6 - half tap on the button, with a long tap going back one level
i consider that the next best thing to ramping
(though i have never seen a good ramping UI til anduril)
wle
Hi Rey! First, I will be honest: I don’t own any of your lights, yet! Only some lights with your “old” drivers! I will need to save some to finally get one of your lights :blush:
Anyway, I will give you my input on this, based on my assumption of what could be good or “useful”.
Here’s my proposal, picking your own suggestions.
- Having a range of modes from which you can choose (from 1 to 5/6, in which “1” is a true moonlight and “5/6” is the highest output). By this I mean, having the possibility to have only 1 mode or all the 6 modes in use.
- Having double click for turbo from any mode (and a double press to get back to the previous mode).
  • Having that longer press to access RED with a further half press to alternate between “low RED” and “high RED” levels (and eventually RED strobe if you really want it). Again, a longer press to return to the regular white LED. Of course, this part would only work well with reverse clicky switches.
As you suggested, having the possibility to turn the memory ON/OFFm, turn moonlight ON/OFF and to choose modes from lower > higher / higher > lower modes is appreciated.
These are only suggestions with some the intents of:
*having that true moonlight,
*having shortcut to turbo,
*having the possibility to choose the amount of modes in use,
*have RED light outside the regular cycle,
*not having blinking modes.
Hope you find it useful in some way!
I really appreciate the number of group mode options available in the Dawn’s modified Bistro UI. I like being able to have 5-6 well spaced modes, ranging from very low moonlight (could be lower on the Dawn) to max regulated. I rarely use FET/Turbo, but appreciate being able to get to it in the hidden modes with medium (really quite long) press enabled.
Thanks, Rey!
I love the mode spacing on my current reylight’s (Ti-Lan and Pineapple), i really appreciate the true moon mode.
However, if i for instance turn on the light, and when i have turned on memory (just found out recently it has that feature, didn’t even know that) and when it has memorized a high mode, i would love to be able to select a lower mode (for instance with a long press, just as the original BLF X6 or A6 firmware) instead of going into a even higher mode.
So for me, please keep the standard UI and use a reverse mode by using a long press.
Hey Rey, I am also a fan of the Pineapple modes. I would like to see a longer press reverse to the next lowest mode. I would think the secondary could be selected by an even longer press as well. One of the things I like about your drivers is their simplicity. I can hand a Pineapple to anyone and they can make it work!
Well this is exciting! I love anduril and would love to have it on a reylight somehow.
Photon Freedom had a good one a decade or so ago and still is a good one!
And yes, I love the BLF A6. Had a few lights built using it because it has a good moonlight, nice levels, the reverse order with long half press….
Agree! I don’t mind if blinkies are hidden. Triple click or something (Like Zebralight). I use at night when walking home and crossing streets at night. Stop signs are sometimes meaningless and need to attract attention to myself. But your suggestions are excellent!
I really like the UI in the TiLan and Pineapple. I think it is good the way it is. Just wan to request that you don’t glue the mcpcb to the shelf. You have the best host and great driver, but just don’t like the emitters.
I’ve been eyeing a brass Pineapple V3, but will likely want to swap the emitter. Is the mcpcb glued down? That could be a problem.
Yes it is glued. Rey said it is removable but I don’t have the technique to do it without damaging the pill
Powers of two, yeah. But…
What do you mean with output? I mean, all of you. Because light output ≠ current output.
If we refer to driver output current the mode spacing needs to be bigger than just twice, at least if we aim to see a doubling in light output for each subsequent mode.
You know the human perception of light output is not linear?
There’s a reason flashlight manufacturers use mode spacing of 1, 10, 30, 100%
:sunglasses:
I might have something like this:
Operation:
Single click - On/Off
Single tap - Mode sequence (Looped)
Double tap - Shorcut to 100% White
Triple tap - Shortcut to 100% Red
Configuration:
10 clicks to enter configuration, after voltage readout it will give 6 solid flashes, each flash stands for a given function.
Is voltage readout and/ or a thermal stepdown a possibility?
Config Menu:
0 .Cell voltage readout possible? in actual blinks (3.8v = 3 blinks, - 8 blinks)
  1. Select a mode group, from G1-G15
  2. Moonlight mode on/off.
  3. Mode memory on/off.
  4. Reverse mode order, H-M-L to L-M-H.
  5. Thermal config stepdown possible?
  6. Reset. (Default. 100, 20, 2, 100 Red) H-M-L-R
Mode groups:
(Double tap shortcut to 100, Triple tap shortcut to 100 Red)
1. 100, 20, 2%, ML
2. 100, 30, 5, 1, ML
3. 100, 35, 10, 2, ML
4. 100, 40, 15, 5, 1%, ML
5. 50, 10, 1%, ML
6. 100, 20, 2, ML, Red 100
7. 100, 30, 5, 1, ML, Red 25, Red 100
8. 100, 35, 10, 2, ML, Red 100%, Red breathing
9. 100, 40, 15, 5, 1, ML, Red breathing, Red 25, Red 100%
10 100, 40, 15, 5, 1, ML, Red 100, Red 25%, Red breathing
11. 50, 10, 1, ML, Red 25, Red breathing
12. 100, 30, 1, Red 100, Red Beacon, Red Strobe100, White Beacon, White strobe 100
13. 100, 30, 1, Red 25, Red breathing, Red heartbeat strobe.
14. White 30, Red 100, Red 25%, Red breathing, Red heartbeat
15. White 30, White breathing, Red breathing, Red 25, Red 100%
Hidden group: (White tactical strobe)
When the light is on, press and hold the switch for 1.5-4 seconds.
yes, that is exponential, not linear
wle
Isn’t “1 2 4 8 16 32 64 128 256 512 1024” actually a geometric sequence?
I believe it is an exponential sequence, but I think modes work better when you multiply by about three (instead of two) between modes.
That was my understanding as well.
1.Red25- red100- white2% – 25% – 100%
This is what Krystal should have offered.
Hidden is intuitive but turning off and back on quickly can trigger accidentally.
I have x2 Lan, a Pineapple and the Krystal….I love your work.
