Hi Rey! First, I will be honest: I don’t own any of your lights, yet! Only some lights with your “old” drivers! I will need to save some to finally get one of your lights
Anyway, I will give you my input on this, based on my assumption of what could be good or “useful”.
Here’s my proposal, picking your own suggestions.
- Having a range of modes from which you can choose (from 1 to 5/6, in which “1” is a true moonlight and “5/6” is the highest output). By this I mean, having the possibility to have only 1 mode or all the 6 modes in use.
- Having double click for turbo from any mode (and a double press to get back to the previous mode).
- Having that longer press to access RED with a further half press to alternate between “low RED” and “high RED” levels (and eventually RED strobe if you really want it). Again, a longer press to return to the regular white LED. Of course, this part would only work well with reverse clicky switches.
As you suggested, having the possibility to turn the memory ON/OFFm, turn moonlight ON/OFF and to choose modes from lower > higher / higher > lower modes is appreciated.
These are only suggestions with some the intents of:
*having that true moonlight,
*having shortcut to turbo,
*having the possibility to choose the amount of modes in use,
*have RED light outside the regular cycle,
*not having blinking modes.
Hope you find it useful in some way!
