I really like the UI in the TiLan and Pineapple. I think it is good the way it is. Just wan to request that you don’t glue the mcpcb to the shelf. You have the best host and great driver, but just don’t like the emitters.
What do you mean with output? I mean, all of you. Because light output ≠ current output.
If we refer to driver output current the mode spacing needs to be bigger than just twice, at least if we aim to see a doubling in light output for each subsequent mode.
Operation:
Single click - On/Off
Single tap - Mode sequence (Looped)
Double tap - Shorcut to 100% White
Triple tap - Shortcut to 100% Red
Configuration:
10 clicks to enter configuration, after voltage readout it will give 6 solid flashes, each flash stands for a given function.
Is voltage readout and/ or a thermal stepdown a possibility?
Config Menu:
0 .Cell voltage readout possible? in actual blinks (3.8v = 3 blinks, - 8 blinks)
Select a mode group, from G1-G15
Moonlight mode on/off.
Mode memory on/off.
Reverse mode order, H-M-L to L-M-H.
Thermal config stepdown possible?
Reset. (Default. 100, 20, 2, 100 Red) H-M-L-R
Mode groups:
(Double tap shortcut to 100, Triple tap shortcut to 100 Red)
1. 100, 20, 2%, ML
2. 100, 30, 5, 1, ML
3. 100, 35, 10, 2, ML
4. 100, 40, 15, 5, 1%, ML
5. 50, 10, 1%, ML
6. 100, 20, 2, ML, Red 100
7. 100, 30, 5, 1, ML, Red 25, Red 100
8. 100, 35, 10, 2, ML, Red 100%, Red breathing
9. 100, 40, 15, 5, 1, ML, Red breathing, Red 25, Red 100%
10 100, 40, 15, 5, 1, ML, Red 100, Red 25%, Red breathing
11. 50, 10, 1, ML, Red 25, Red breathing
12. 100, 30, 1, Red 100, Red Beacon, Red Strobe100, White Beacon, White strobe 100
13. 100, 30, 1, Red 25, Red breathing, Red heartbeat strobe.
14. White 30, Red 100, Red 25%, Red breathing, Red heartbeat
15. White 30, White breathing, Red breathing, Red 25, Red 100%
Hidden group: (White tactical strobe)
When the light is on, press and hold the switch for 1.5-4 seconds.
Thanks for your input.
Let’s assume that I was at low mode, and I want to get to high mode; if I click rapidly (let’s say 2-3 times within 1 second), I will be forced into the hidden mode.
Zebra uses electronic switch, reverse clicky is quite different. 1click= next mode, 2 clicks= next 2nd mode, 3 clicks= next 3rd mode.
It can ealisy cause some confusion.
I love the spacing of LAN/Pineapple. One thing I would note though is I occasionally overshoot or over estimate how much light I want / need and inadvertently enable mode memory. Not sure if anyone else has this problem . Also, handing these lights to muggles is a guaranteed switching of mode memory. Personally, I would like to see config mode require more than 8 clicks.
I do understand your perspective and concern about the double click making us enter the “hidden” mode (Turbo). I guess that in a reverse clicky will always be hard to control the amount of pressure and the timing to make it act correctly.
Some time ago I made some demonstration videos with the guppy3drv firmware by doctor Jones. In this driver/UI you can choose some configurations where you can double click for turbo from any mode and a half press takes you back to the previous mode.
I tried to demonstrate that you can “manage the timing” of the double click, but it is true that it is not always possible to get it right.
However, take a look here.
Maybe there is another option instead of 2 fast clicks, but I really, REALLY, think that having the possibility to enable/disable a double or triple click to turbo would be awesome in a reverse clicky flashlight!
Hope this helps
I also made another video showing it with forward switch but I guess it will not be useful in this project.
