I haven’t been edc’ing this much because I’ve had trouble pushing it in my pocket without pushing the button. But today I might have cured that. I’ll see how it goes.
The ‘extension’ is something i lathed up. Very similar to the washer pic below. It is just a press fit (finger press). Not glued because I didn’t know if i would like it. Been edc’ing for several days now. No issues at all wtih accidental turn on. The extension has also not slipped off despite only being pressed on finger tight. Definitely a worthy mod IMO.
battery ground on driver
the positive can be also used with MCU with a proper flashed Firmware to enable it
and don’t worry the board version with the outer lane to crack sometimes is fixed a long time ago
stupid fab placed the break drills too wide into the board
Thanks, still fine tuning it a bit. I need to get another o-ring for it though, forgot to take it out before I started removing the anodizing and it has now disappeared. The glass lens rattles a bit without it.
