Two cheap flashlights that are a great buy
When throwing, is number 1 or 2 better?
For a thrower you want this one:
I think this is the one I posted a beam shot. Nice focused pure white beam. Very good for the money
I’m a little curious about #3. Please update us when it shows up.
Be careful with included batteries, most of the time they are junk. The included chargers are always junk.
I have had three of them for over a month!
They do ramp. Not as slick or fast as an FW3, but they do work.
I tested the included batteries, they are nearly 4000 Mah and run the light for a long time. I ran it 45 minutes on the highest setting before it ramped down, and they do NOT get hot.
So it is a good general use light. It has a focused pure white beam, has a pretty decent throw.
No memory, when you turn it off it always turns on at the brightest level.
Would be good for something like a security patrol, you can light up nicely and it runs a long time. And heavy and long enough to use defensively if needed (probably break the light though).
I like it, for general use it is way better than the L6 with the smo reflector, because it is much lighter and does not get hot.
Again, it is cheap and you can get it in one or two days from Amazon.
Beyond that, it is not on a par with many of the lights mentioned on this forum. But it is cheap and works well. And it does throw a nice amount of light, way superior to all those T6 zoomies you see around.
This “P70 XHP50’’ ”light”:https://www.aliexpress.com/item/33052880063.html?spm=a2g0o.productlist.0.0.34612452zyPiOV&algo_pvid=165ba82f-937a-41a2-ac00-0d519dbd92fb&algo_expid=165ba82f-937a-41a2-ac00-0d519dbd92fb-0&btsid=cf849fbd-815c-4078-a8cb-6a89678393cc&ws_ab_test=searchweb0_0,searchweb201602_7,searchweb201603_52 cost 13 usd
I would see diassembled
Since I wrote that I have bought many brighter lights. It still does well for a zoomie.
Just got mine and played a little with it. This thing is not what I expected at all, and that’s not in a bad way. The beam has good spill, and good throw, with an outside spill ring that’s sort of bright. The housing itself is massive and actually quite decent looking and of good quality. It’s no exotic nor high tech, but it “checks all other boxes”. I do notice the button turns red on high but green on low. Batteries are full according to its own charger. I didn’t try my xtar charger yet. It also has a port for charging but didn’t come with any charger, which is interesting. I guess this is what a product would be if someone knew how how make a light but didn’t have a full team or time to refine it. It definitely scores a B to B+. And obviously if it scored higher it would’ve cost more. Yep a “hidden” gem in a massive flooded market.
For another $5 or so they sell the same thing with a charger. BUT I have been warned against charging batteries in series so probably better off.
I tested the batteries they show close to 4000 Mah, so not bad.
The switch is defective. It should show green, I have a one cell that does that.
But in the end, so what. Light works just fine, the green switch is just a bonus.
Of course, you can return it to Amazon and have it replaced.
I actually like this light. I find the beam very attractive, pure white, not a hint of blue.
and the narrow beam gives a good focus, the spill is not distracting when you are trying to look at something.
If you want to try, the charger is 8.4 volts and it is a common adapta plug. Center positive.
The company will send you a charger if you contact them on Amazon.
I tried a 9V universal adapter, and it showed charging. But I did not want to push my luck with extra voltage, so I just did it as a test and stopped.
Wait, there is no high or low, it ramps!
The spill is large, it is arguably useful for everything closer. And the switch is doing green sometimes, I feel it’s either the battery or the voltage sensor that’s bad and confusing the switch to think it’s low on battery. No need to try return, I have no confidence this is something that is reliable or bothered by the manufacturer. The packaging tells me that they want to sell this quick and in volume, and that’s just fine by me at this price point with what I’ve got.
Perhaps China manufactures really have some magic and we don’t even know our buying power
No, mine does high, low, or ramping by holding the button. It goes only one direction until the end with some quick flashes indicating the end. Then if you let go and hold again it will ramp opposite direction. Any time before end is reached if you let go, and start again you continue the same direction.
Correct, but there is not steps for high and low, it just ramps.
Again, I have one of theirs with the same switch behavior, it does not affect the operation of the light at all.
Maybe the firmware got updated, it does hi and lo for me for sure. Does yours also have a charge port in the body? I know they sell another with charger I wonder if they consolidated 2 models into one and only give charger for the pricy one and same light but no charger for the cheaper version
No. That is a defect. I have three, one of them has that issue. However, it you leave it on any level including start up for around 10 seconds, one click shuts it off.
Personally I can live with it.
BTW the one with the charger comes with a battery pack, rather than individual batteries, but same exact light.
I don’t think you can call that a defect. :slight_smile: hi/lo/off. Maybe the ones that can’t do that is the defect :smiley:
Scosgt, Ok the battery was low, tested as ~3.8. After I charged it full no longer turns button red. Also, the stepping I’ve noticed that you can only step if you immediately press the button after on (hi), if you leave it on hi for a bit then press again, it will turn the light off. I guess that’s the ui. So maybe that’s why you thought it doesn’t step?
One of mine does, the other two do not.
Not sure this was the intent, but matter, it just works.
Does not get any press here, but it’s a pretty handy light
