Osram flat white centering gaskets
Hello guys.
Where can I find centring gaskets for Osram flat white 1mm in Standard P60 pill?
Thanks, Mike
Oh… that would be great! Will be following this one, I still build quite a few P60’s.
I know Simon sells gaskets. I’m not familiar with P60 pills, maybe it helps.
3030 gaskets from Simon
Cheap, and look like they would fit in a normal P60 reflector. Then I would need 1 or 2 led and mcpcb’s. Would really make a compact P60 thrower with that setup.
Kaidomain has gaskets too now, for 7mm reflector hole.
Link
I’ve got them from BG shop
Link?
Post #3
Guys, What will be the best 1x18650 host for that led?
Mike
One with the largest and well shaped reflector.
Rumours say Emisar is going to release the D1Sv2 with 500kcd
Now I put this led to Solarforce M3 head, but I look for better hosts if any…
Mike
