To compile a hex file in Amtel Studio 7
The how to do in Amtel Studio 5 can lead to errors if the file also needs to load information from the config files, you see more files in the Bistro HD folder
You can simply load the BistroHD.c file
And then start from build in the how to create hex in studio 5
The studio will have also the other files
Right click on solution explorer on the right side
Click on add new project,
Remove the main.c
Add existing Item BistroHD.c and the other files
from there you can use the how to in the BLF topic from comfychair
Comment out or disable just add // in front
Enable remove //
For different PWM channels you need to enable or disable the channels in top section of the file, read the comments on the code lines they tell you what to do
There is only one hex file!
The Amtel studio loads from all those config files what it needs and build a flash code in the hex file
If you got the hex file you need also use the right fuses to flash the driver, most will have add a .bat file to do so
New project
Select your Chip
if you use a different than the 25 you need to change that in the BistroHD.c file as well
Delete the main.c
Getting the files loaded
Load all the files for the solution
Building the hex file
here you find the hex files
fuses
the text file is from Texas Bistro including the whole command prompt to flash
