Linear CC, PWM’ed FET or other type of driver?
Emitter options?
Driver LVP and reverse polarity protection? Protected cell seems an odd choice for a quad hotrod (at least I assume its a bit of a hotrod since you made it )
Emitter options?
Can we start with the copper version right off the bat? Fine, I’ll take two. The clip actually is such a nice minimalist design, gives it a post-modern look. Designer is an artist
XP size footprint for the 14 LED option
It will be a while until I can do runs with exotic metals as collectible but it would be cool to make a few.
:heart_eyes: How does it fit though? That will be mule for sure right.
That’s the fun part
14 LEDs??!! It’s 100% Mule and I am in if you show us some pictures
What made you decide to go with tube walls over half a centimeter thick?
This light engine is in design phase. Was going to do 16. But actually might reduce to 12 to improve trace width.
Its only 5.77mm at its thickest with out threading
No. I mean 14 (or 12) installed in the light. Light engine option wise there can be like +50
I got this budget Infared Thermometer on Amazon for number 5 heat test. Seems off. For example my wall seem colder than 72F and, my skin less warm than 88F, a metal surface I heated up that is burning to the hand was only 200F, icecream in the freezer at a low 17F. I guess worst case we will just use it as a guidance on temp changes rather than accuracy. I am sure someone here got one right? Are these numbers way off?
the wall could be right. you can try your temple or the inside of your mouth, should be >90
problem is two things though, these are terrible with taking temps on reflective metals and second where that laser pointer is and where it’s actually measuring can be pretty far off on something as small as a flashlight
By the way its crazy how much adrenaline I went through. Doesn’t seem much on video but I was crazy nervous and excited. Off camera we did a test run over a “normal” light and yeah it was crushed. That made me soooo worried!
I was thinking if the head got crush then I will be VERY screwed! I wouldn’t know what to do. Literal devastation. I am so happy we made it this far. In fact I couldn’t sleep more than 4 hours last night thinking about everything and what’s next. Whooo
That thick wall of 7075 aluminum might as well be a solid chunk of steel!
I hope you can keep it 7075 for future runs as well.
And yeah your voice cracked quite a bit during the videos you definitely were full of nervous excitement.
Tested Proto V3 is 2011 which is softer than the First 30 Production 7075.
I am guessing the 7075 will handle the physical abuse a little better. But also hoping the 2011 will handle the next heat test better.
Silly question, are these taking modular drop-ins?
What is the advantage of that many emitters in a host this small?
Also a good final test would be a drop/throw test I think, impact resistance would go a long way to showing durability too!
This specific will be revealed close to the release with official production pictures and details.
