[Preview] EDC18 by Lumintop - FIRST LOOK of a Anduril sideswitch EDC flashlight
Look closer, it is designed differently. There is no inner ring. They kept the same FET+7+1 architecture and software because it works just fine. I don’t think there is a problem with AMC’s getting hot. They can handle over 250°C during reflow. I have not heard of heat being any kind of issue. Have you seen reports of heat being a problem for the AMC’s?
I’ve seen nothing anywhere that answers the following:
  1. Is the side switch illuminated?
    If so,
  2. Can the side switch be controlled by Anduril?
  3. Is the side switch only one color LED, or is it multi color?
  4. Can the side switch be used as a locator?
Anyone know the answers to these questions?
Thanks!
1 yes
2 yes (seems possible, have to wait for confirmation)
3 single
4 it stays on, so yes.
Great, thanks!
I felt kind of dumb asking the question since it seems like such an obvious bit of information that would be posted on the product page or otherwise readily available.
Just curious so I know where to look next time before I ask… where did you find that info?
@M4D M4X
Can you please weigh the EDC18 when you get a chance?
I feel the 53g spec on Banggood is incorrect, copied over from the FW3A specs.
I am familiar with the pinouts on the Attiny85 and the Anduril code.
I did not find this info about the EDC18, but I can deduce it based on the hardware.
my kitchen weight gives me 75g (prototype)
have you watched my video?
1. yes
2. i am not sure
3. yes (green bunny)
4. its on in "standby" so: yes
Concerning #2, Anduril can certainly control the switch light with options like off, dim, bright and blinking. We see this with other side switch lights using the same driver parts and Anduril. I see no reason why Toykeeper would disable this function in Anduril. There is no reason to. I have to assume it is controllable. (Better to assume it’s not controllable, waiting for confirmation)
I don’t know if your prototype can do it, but try this. From Off, do 7 fast clicks and see if the switch light changes. To cycle to the next option, repeat with 7 fast clicks.
Here is the newest Anduril cheat sheet.
You can try the color change as well, but I doubt they installed multi colored LEDs for the switch. 7H means 7 fast clicks and Hold the button on the last click (iirc).
Got in on the preorder thanks. Not that I need another light :smiley:
I think the bunny is wired to the battery
it's not controlled by Anduril
Fireflies also had only 2 of 4 leds in the switch controlled by the UI
(also my sample only has one Lockout brightness)
So what did I preorder?
Yes, I did watch the video M4D M4X. Thanks for putting that video together. However, it didn’t cover what the switch light actually did. It looked like it was illuminated.
Sounds like there is still some confusion on exactly how the illuminated switch function works.
i hope i get one of the first sale version lights to clear all questions
I got in on the preorder! Thanks for the code!
:beer:
Nice light, is it mod friendly like the fw3a? Doing reflows to nichia possible?
Hmmm, I guess they can choose to do it that way. It’s simpler. I know pin 1 on the mcu is unused. I would think it’s capable of a switch light output. Maybe not. I’ll ask Toykeeper if she wrote a version of Anduril for this light.
Yes, there are 2 basic ways to send power to the light. Either constant battery power or a PWM signal from the MCU. I will ask the software writer. It’s possible Lumintop made their own decision.
Until we know for sure, I would assume it stays on all the time that power is connected. (I actually like this because you can easily tell if it’s manually locked out or not) I will report back if I learn anything.
Okay, I found out that pin 1 is physically not capable of controlling a switch light.
This means the switch light is a simple battery direct led. It can not be controlled through Anduril.
Fireflies probably used a 2 channel driver which freed up an extra output pin to control it’s switch light.
