I would like one.
Texas_Ace BLF Calibrated Lumen tube / Sphere No math skills needed - Several spheres still available
Hello,
Hope it is not too late!
I would like to purchase one 3.5”
I have messaged you.
Thanks.
Thats about right… i got 14040 lumen @ turn on with my d18 sst20 6500k… i find sony vct5a solder blop make about 1000 more lumen than 30q.
I really need to get on this list for the 4.5” version, How can I
do that?
Howdy, The ground buy / list is over, I am now just making them 1 at a time from spare parts by ordering the missing parts as needed. Now to get one you just need to send me a message.
I am sending you a PM and we can sort it out there.
TA, sorry to bother, but since i am trying to build one myself, i am interested in the most important things which i have to take in mind to get a reliable setup.
I am using three white 90 degree pvc bends , use a glass lens inside the tube to have always the same distance to the luxmeter and i am using a frosted pvc piece inside the tube as a diffuser.
What other factors do i have to take in mind?
What about linearity ?
How to optimize the lumen tube to get a good setup?
Thank you in advance
The diffusors are the mot important part. Using the right kind and multiple layers is the best option for balancing out different beam profiles.
Using glass as the first layer is ok, but I find it to be a better result when you capture all the light with the reflective centering rings. This stops the light that is reflected back out of the tube from skewing the results too much. This makes it more like a classic lumen sphere then a classic lumen tube.
Basically a hybrid lumen sphere/tube.
Past that it is trial and error to get everything figured out with the specific materials and setup you are using. Luckily Now that I have built several of them I have most of the details figured out but there is still quite abit of individual testing and calibration for each tube. No 2 seem to be exactly the same for some reason so I gave up and accepted I would have to build them all individually.
Sucks since I could cut the time per sphere drastically if I could just slap them all together the same way and they would have the same results.
Thank you TA, i will try that.
Strange indeed thet every tube gives different results even when you built them all exactly identical, probably small deviations in production of materials, hardening of material when they come out of the mold, or something like that.
Yeah, the materials can be different for sure. Another factor is that every mm difference in how far they are pressed into each other has a surprisingly big effect on the final readings. Since it is basically impossible to full bottom them all out this varies tube to tube enough that the readings have to be individually calibrated for each tube.
Another question, i noticed when using high output lights, the white walls do light up slightly, do i need to paint the outside black?
No, light escaping into your room or being absorbed by black paint is the same thing, in both cases it leaves the tube.
Btw, integrating/measuring total light output is not about getting as many photons to the detector as possible, it is about any photon emitted by the light source at any direction having the exact same chance to reach the detector, but that chance by no means needs to be high.
Thanks for that info!
Still struggling to find the correct conversion factor, i just found out i have to many lights that are modded or lights i dont know the exact lumen output of, besides the fact that the output drops quite fast even on fresh charged cells.
Is there a good and cheap method to have a calibrated light ?
Does this reflect light across the wavelength evenly enough?
What is enough? My integrating spheres show a resulting spectrum with reduced blue (about 600K CCT-shift if I remember well) after multiple reflections, and every diffuser in the light path causes extra blue loss too. This tube has both multiple reflections along the way and two diffusers so I expect a rather large effect on the spectrum. But the main affected region is the blue region which contributes relatively little to the lux-measurement. Moreover, the cheap luxmeter used in this device over-reads blue so a bit compensation may not be bad .
But to answer this question thoroughly, one needs spectral measurements on the device which has not been done, to see the amount of spectrum-change, and the amount of accuracy-loss when light sources of a wide range of CCT’s and CRI are tested. If it is really bad, a different multiplier per CCT-region could be used to compensate for that.
Well, I thought about the idea of measuring integrated tint shift. I guess this doesn’t cut it for this use case.
As djozz said, yes it will cause a tint shift of some sort, how much and to what degree, I do not have the equipment to test but his results backup my anecdotal evidence.
I have noticed that my high CRI warmer tint lights don’t seem to read as low on this tube with the diffusors as the old style without them. I still round them up but not as much now.
The end point though is that the exact tint hitting the meter really doesn’t matter all that much for what we are doing. This is a cheap, crude and basic version of a very expensive piece of equipment. It was never designed to be perfect, just as good as I could make it for a reasonable price. I have never said otherwise.
Just giving this thread a bump since I still have enough parts for a few spheres.
I just had my video card die on me so trying to replace it but don’t have the funds in the budget for it right now so trying to make a bit extra.
I would be willing to trade for a video card.
Looking for a video card in the RX 480 / RX 580 or better range preferably but an RX 470 / 570 might work as well.
Also on the lookout for a socket 1155 motherboard / a whole computer of ~2500k performance level or better for my Mom.
Don’t have an extra video card now but I plan to upgrade when the Nvidia 7nm comes out, which is about a year from now. I can send you my current one. I’ve been so busy with work and family that I still haven’t had time to get to going through my old harddrives to transfer out useful data. Probably will be sometime next year before I can get to it looking at my current schedule.
No worries at all. Thanks a lot for the offer, when you upgrade I would be interested in that indeed. By then the mod options we have been talking about might be ready.
For now just trying to get something in the system that will at least run all 3 of my monitors and play some games, I am so spoiled I just can’t handle not having multiple monitors anymore lol.
Hi
I am so glad that see you have made this type of LumenTube yourself
But I have some questions that maybe you like to answer me
First : Is anyone else made lumen tubes lnstead of lumen speheres? In Theory I think that you are right, But I just want to know , is this typical or is it your invention? and did you test it and what was the result and accuracy?
Second : In British standard, As I remember, It says that Lumen Sphere’s paiting must have more than 90% reflectivity , And I have searched and found that only paints based on Barit can have that reflection , and paints based on Titan have less than 85% reflectivity , Now I like to know, did you paint inside of yourtube? and Is it isolated from outside?
Third : I want to use this lumen tube idea for Luminaires that are generally much larger than flashlights , Is it possible to change the plan , so it can fit larger lights , and does it result well for all types of luminares? (for example wide beam or narrow beam ones as well)
Fourth : Is it possible to use standard LED Diffusers as diffuser?
Thanks alot for reading.
