Emisar D4S review
The aux led is under the UI option as mentioned by wolfstyle
Nope, amber option is limited to single colour only
I’ll have to weigh some… the 21700’s are 5mm narrower but also 5mm longer so the size issue should very nearly be a wash…
Edit: An 4500mAh 26650 Golisi Gold is barely a half ounce heavier than a 3000mAh Samsung 30T, so I really can’t see weight being a problem. True, the 26650 is almost a quarter of an inch wider, but it’s also the same measure shorter. So again, the differences are so small as to be very nearly unrecognizable. If you are so close to failure at carrying weight that a mere 1/2 oz could make or break you, then the problems you face are much larger than which battery selection to choose.
I understand that carrying a wider light, even less than a quarter inch wider, in silk suit pants might well be problematic, but then, anything of any comparable size would also be an issue. At which point, pocket carry would have to be dismissed and a belt carrier figured out. This light offers unparalleled output for it’s size, and it does that by using a readily available 26650 format. Granted, the 21700 is making inroads towards popularity in Li-ion cell choices but still it’s availability is much more limited than the 26650.
A neck light may well be of consideration if carrying a flashlight is problematic. Output and run time will suffer, but then, that’s what compromise is made of…
E07 is more EDC friendly than D4S and they have the same head diameter
But apart from the size, I sold all my 26650 lights and cells, I’m only keeping the ones that also accept 21700, I’m done with having a lot of battery sizes
It depends upon each person’s needs and how they use the light. In my case the 26650’s would be the last ones I would sell. Each to his own.
If I calculated this correctly, the 21700 cell is 83.36% of the 26650, yet the 26650 has 50% more capacity. So the 26650 is much more efficient for the capacity it holds vs it’s size. I probably missed something somewhere, usually do. :wink:
Close, but not what I’m seeing.
Dropdown 1 - choose body color
Dropdown 2 - “IOS V3 UI” /or/ “Anduril UI (the same aux LED function as the D4v2) +$1.99”
Dropdown 3 - LED selection
Then some checkboxes for Aux LED colors.
Nothing here says the checkboxes are only for the Ramping OS V3 or that choosing Anduril gives you RGB.
So… Is the RGB AUX hardware in ALL new D4S but hardcoded to a specific color if you choose Ramping, or is a different LED/Aux board put in if you choose Anduril?
I see now, not just a cost to flash the new firmware, but that also includes the leds!!! Is not very clear on the selection page, since there is a place to select the aux colors.
If you choose Anduril in the 2nd option, just omit the third option. Otherwise it’ll be the old style single colour aux led if IOS V3 UI is selected.
Maybe Hank should just consolidate the single aux led options in the third option to the second one for better clarity.
True, the E07 is an excellent light, very slim and lighter than the D4S. However, I much prefer my D4S which I comfortably belt-carry in an old Thrunite TC20 holster.
The E07’s light weight means less mass to cope with the heat buildup while pumping out all those highly advertised lumens. Also, its extreme flood beam can’t compare (IMO) with the more focused projecting beam of the D4S. Even with SST 20’s the D4S still is the best combination of throw and flood of any light of its size that I have ever owned or heard about.
Without doubt, the D4S is a mini-Masterpiece!
this was a good starter for me so i added some comments to help me understand. What is the maths involved to get these integers in the PWM1_LEVELS? If I wanted to cut PWM on FET to 80, would my end value be 204? I see 128 for 219c on fw3a so 50 PWM (a bit conservative imo, so id like to increase pwm to 80%)
You may have missed the third dimension. 26650 is 26*26*65 and 21700 is 21*21*70. (with rounded corners). Volume is directly proportional to lengh and to a square of diameter. So 21700 is 70% of 26650. And capacity / volume? It may get close at certain discharge levels but most of the time 21700 wins.
For the volume of a cylinder you square the radius not the diameter
It’s just a matter of what constant do you multiply by later, pi or pi/4. So it’s directly proportional either way. And the constant goes away anyway when we express volume of one cyllinder as a fraction of volume of another.
I have been using this one
I actually used an online calculation that allowed plugging in the cylinder’s dimensions and gave a total volume. :wink: (Already knew I didn’t miss anything. :stuck_out_tongue: )
Most of the time? Really? So 4500 mAh is not 50% more than 3000mAh? I have run lights on both the Golisi Gold 26650 and Samsung 30T 21700, I know what each actually gives to a light with high demands, and I’m familiar with how long each cell can run a 23,000 lumen light, so I really don’t see the theoretical point when I have actual results before me… I have the new HOhm Run 3000mAh 21700 arriving today, they claim a constant 39.5A and pulse 48A, so I will use it to feed a hungry emitter and see how it compares to the 30T and Golisi Gold. The CFT-90 can take it, regardless of what the cell can do, so it should prove interesting… (yes, I’ll also test the HOhm Run 21700 in said 23,000 lumen light and see what it’s 17 emitters have to say)
Does anyone tried the flat white 2mm² in the d4s yet? really curious about throw and heat.
I tried the White’s in a D4, didn’t like em under the optic… promptly removed them.
Tweaked my pretty blue D4S to take an 21700 today. Only getting 5360 lumens so I’m not sure it was worth the hassle. What I did was remove the tail PCB and then shaped a copper disc to fit into the magnet space. Removed the Beryllium spring from the PCB and soldered it to the copper disc. Then went out to the lathe and cut an aluminum spacer to ground the battery tube to the tail cap. Only needed to be 1.34mm thick so it was a lot of hot for the little bit of part. lol
Hank seems to sell V1 and V2 on the same page now, based on whether the customer chooses RampingIOS or Anduril. If I recall correctly, the differences are:
D4S V1:
  • RampingIOS V3
  • FET+3
  • Attiny85
  • Single color aux LEDs
D4S V2:
  • Anduril
  • FET+3+1
  • Attiny1634
  • RGB aux LEDs
The physical design of the light seems the same though, probably because Hank got it right the first time. Aside from the overall size and weight being a bit much for EDC purposes, I think the D4S is probably the best design in Emisar’s product line-up.
I still don’t have a blue one… but I probably should.
It comes with RampingIOS V3 or Anduril. RampingIOS V3 is basically Anduril with a few things removed or rearranged.
To quickly tell which is which, make sure the light is off and then do a “click, click, hold”. In other words, click 3 times but hold the third click for a second or so. If it goes into a candle-like mode or some sort of strobe, it’s running Anduril.
Anduril has a tactical strobe and a motion-freezing strobe, and both have adjustable speed. There’s also a bike flasher with adjustable brightness, which I’d recommend for crosswalk purposes.
RampingIOS has no strobes.
The RampingIOS version has a single-color aux LED board, and the Anduril version has a RGB aux LED board. It’s different hardware — a different driver and a different aux board.
